Rear diff service question on 280se - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-21-2014, 06:48 AM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Hi
i have serviced the rear diff on my Land rover and truck before. Are there any things i should know or is it a straight drain and refill?
Also which oil should i use?
Thanks in advance.
John.
wroding is offline
post #2 of 9 (permalink) Old 05-21-2014, 07:03 AM
Date registered: Aug 2009
Quoted: 70 Post(s)
The first thing to do is to loosen the fill plug BEFORE you drain the lube. The Benz plugs are notorious for being hard to undo.
Mike D is offline
post #3 of 9 (permalink) Old 05-21-2014, 07:22 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
80/90w oil , the wheels must be on ground or ramps when doing this , so the axle stay straight . the oil in rear end last almost for ever .
adler likes this.
agillot is offline
post #4 of 9 (permalink) Old 05-21-2014, 11:10 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Much appreciated.
Cheers john
wroding is offline
post #5 of 9 (permalink) Old 05-22-2014, 08:15 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
If you want to get ALL the oil out raise one side then the other to allow the oil trapped in the axle tubes to run out. You would be suprised at how much more comes out especially if you have some positive camber.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #6 of 9 (permalink) Old 05-22-2014, 08:37 PM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks for that advice I would never have thought of doing that.
Cheers John
wroding is offline
post #7 of 9 (permalink) Old 05-22-2014, 11:55 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Tony
What oil grade do you use in a 3.5 ?These are not LSD units as I understand
Ad
adler is offline
post #8 of 9 (permalink) Old 05-27-2014, 12:50 PM
Quoted: 8 Post(s)
I have been in the restoration mode for a while so I'm not really up to speed on the various lubricants but I don't remember anything unique about the rear axle lube-I'm sure others here re more up to speed.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #9 of 9 (permalink) Old 05-27-2014, 02:17 PM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks Tony. I ended up going with 80/90 rear gear oil.
Thanks John
wroding is offline
