1979 SL 350 turn signal - hazard lights not working - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-14-2014, 06:32 PM Thread Starter
Date registered: May 2014
Vehicle: 1979 & 2007
Unhappy 1979 SL 350 turn signal - hazard lights not working
Hello all got an issue with the hazard lights - turn indicators
if you use the turn signal or the hazard warning switch the lights come on and stay on and the switch is making a huge amount of noise (can only assume this is the switch working over time ) - i have noticed the light are not solidly on there is a pulse going through them .
All lamps work
i have pulled the hazard switch out and the best i can i have metered it and it appears to be working - i am assuming this contains the relay for the turn signals as its rather large .
plug section i have 8 wires going to 7 pins is this normal ?
any help would be brilliant i am at a loss now
Mark
markw-e is offline
post #2 of 7 (permalink) Old 05-15-2014, 02:12 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Yep, bad relay (the big, red part of the switch). Time for a new switch assembly.
flyboyike is offline
post #3 of 7 (permalink) Old 05-15-2014, 08:37 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
sl 350 79 , you mean a 79 450 sl .there could be 2 relay on this , the red knob 001 821 88 51 , and a small flasher relay 001 544 97 32 .those 2 part may no longer be there especially the red switch . the red switch has sliding contacts in there that get corroded .
agillot is offline
post #4 of 7 (permalink) Old 05-15-2014, 02:09 PM Thread Starter
so if there is a flasher relay where would i find it ?
markw-e is offline
post #5 of 7 (permalink) Old 05-15-2014, 02:13 PM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
Just behind the gear shift under the dash, try pressing the hazard switch a few times in and out, the relay contacts get bad.
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #6 of 7 (permalink) Old 05-15-2014, 02:18 PM Thread Starter
drivers side or passenger side (its a left hand drive car ) had the panel under the steering wheel out but couldnt find anything .
markw-e is offline
post #7 of 7 (permalink) Old 05-15-2014, 05:46 PM
flyboyike's Avatar
Quoted: 68 Post(s)
Probably because on your car it sounds like you have the one-piece switch/relay assembly.
