Transmission question. - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 05-13-2014, 11:39 AM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D, 1988 300SEL, 1991 300TE
Quoted: 2 Post(s)
The lifter kit is just a few $$ and they come in different sizes. But if you have a pneumatic leveler with problems they you'd have to fix that first - and I don't have that so I don't know.
frankflynn is offline
post #12 of 17 (permalink) Old 05-13-2014, 12:52 PM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
I thought the kit replaces the pneumatic leveler?
John.
wroding is offline
post #13 of 17 (permalink) Old 05-13-2014, 12:58 PM
frankflynn's Avatar
Quoted: 2 Post(s)
John.
Ah - I was talking about a lifter - you remove the spring and put this hard rubber thing on top of the old spring. It will make your spring taller by up to two inches.
The pneumatic leveler it a whole other animal with several different parts. Not all cars had them, my 115 does not. The old wagons do. They are great when they are working.
post #14 of 17 (permalink) Old 05-13-2014, 02:50 PM
Date registered: May 2014
Vehicle: 1988 300e 75 300d 74 450sl
Quoted: 191 Post(s)
the spring kit does replace the compensator for the swing axle. this is not a self leveling system just a compensator to help stop the rear from bouncing around over bumps with swing axle only. 115 body has independant suspension fron and rear and none of them have them. the part at the end of the spring is a shim and they come in different thicknesses for minor ride height adjustments. spring kit can be done but good ground clearance and long prybar is helpful.
remove the old compensator put the spring kit up car with one bolt on the bolting bracket side then with prybar pivot bracket around to line up spring and second bolt hole tighten up and road test
rollin560 is offline
post #15 of 17 (permalink) Old 05-13-2014, 09:25 PM
Date registered: Apr 2008
Can anybody help me, I just rebuilt my K4A025 gear box with less than a 1000km and now it has a clicking noise when you accelerate forward, it doesn't click in Rear or in Neutral. Thanks
sirpedro is offline
post #16 of 17 (permalink) Old 05-14-2014, 06:22 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Hi
I think you may want to start a new thread with this problem to get the right help. Good luck.
all the best John
wroding is offline
post #17 of 17 (permalink) Old 05-14-2014, 01:21 PM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
First test drive.
Well i got that little retaining spring back in, bolted the wheel back on and took it for a short test drive.
It runs beautifully Shifts are smooth, brakes nicely and the power comes on like a steam train!
I'm happy.
John.
PS.... now the wax comes out
wroding is offline
