W114 Dash Night Lights Not Turning On - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-06-2014, 01:59 PM Thread Starter
Date registered: Jun 2011
Hey guys, I'm curious if you guys think that the reason my backlit night light in my dash isn't illuminating when I turn on my headlights because of a defective rheostat or if there is another thing I should be looking at first?
My turn signals, high beams, handbrake, etc... lights all turn on, just not the back light.
Thanks
sandro_bit is offline
post #2 of 5 (permalink) Old 05-06-2014, 03:25 PM
Date registered: Dec 2006
Most likely a rheostat with dirty contacts. Spin the knob 100x and see if that helps.
jmela is offline
post #3 of 5 (permalink) Old 05-06-2014, 05:48 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the rheostat goes bad , just remove it , and solder a wire across , and put it back in .
agillot is offline
post #4 of 5 (permalink) Old 05-06-2014, 08:29 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Actually you don't even need to remove it. It is ceramic and there are two posts in the back, these are hollow and you can take a short (2") bit of small still wire - shove it into one and the other end in the other and the lights will be on full brightness but that was not particularly bright.
While you have it out and are checking the lights you might replace any that are burnt out.
Good Luck.
frankflynn is offline
post #5 of 5 (permalink) Old 05-08-2014, 06:52 AM Thread Starter
Cleaned up the rheostat connections with alcohol and it worked fine. Thanks!
