W114 Cigarette Lighter GPS - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-01-2014, 08:32 PM Thread Starter
Date registered: Jun 2011
Hey guys,
I was curious regarding if it would be possible to power a portable GPS unit into the stock W114 cigarette lighter terminal?
I was told that it would not work because the stock terminal can't handle the increased power needed from a GPS unit and it would keep blowing fuses.
Is there a way to upgrade the stock outlet or some other way to get a portable GPS unit to be powered this way?
Thanks
sandro_bit is offline
post #2 of 17 (permalink) Old 05-01-2014, 09:37 PM
JN74SL's Avatar
Date registered: Apr 2013
Vehicle: Monika '74 450SL and her lil sis BrownHilda '79 280SL
Quoted: 215 Post(s)
I would think that the lighter element would draw more current than a GPS system. Only way to find out is to try it...
I currently run my cell phone, RADAR detector and GPS off the lighter circuit in the 450SL. The one in the W114 cannot be that much different
Current:
Reggie 2010 Range Rover Sport Supercharged
Monika '74 450 SL
BrownHilda '79 280 SL ex-Zender
Scarlett 2014 Jeep Cherokee 4wd
FoxyCleopatra '99 Chevy Suburban
Krystal 2004 Volvo S60
Gone:
Rudolf ‘86 300SDL
Bruno '81 300SD
Fritzi '84 BMW
'06 Volvo S60 AWD turbo
'97 Jeep GC
'96 Volvo 960
'96 Impala SS
'92 Subaru Legacy wagon
'74 Jeep CJ5
'71 Buick GS conv
'67 GTO conv
'63 Corvair conv
'57 Nomad
JN74SL is offline
post #3 of 17 (permalink) Old 05-01-2014, 10:11 PM
Jackpody's Avatar
Date registered: Oct 2012
Vehicle: Mercedes Benz W108 - 280 SE (1970) / Mercedes-Benz W123 200T (1983)
Quoted: 12 Post(s)
I run a GPS in my lighter outlet too, never had any blown fuses. W108 280 SE from 1970.
Jackpody is offline
post #4 of 17 (permalink) Old 05-02-2014, 06:41 AM Thread Starter
OK thanks guys, I appreciate the input. The previous owner suggested against doing it because it would blow the fuses, that's why I asked.
post #5 of 17 (permalink) Old 05-02-2014, 10:57 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 115 Post(s)
Cigarette lighter is way more current than anything else you are going to plug in there. the problem is that Mercedes old cigarette lighters are a slightly larger size and most modern plugs fit sloppy in the lighter hole. You can wedge something in to make better contact if you want... In my W123 I added extra power ports on the kick panel and inside the glove compartment.
Scoot is offline
post #6 of 17 (permalink) Old 05-02-2014, 02:43 PM
JN74SL's Avatar
Quoted: 215 Post(s)
I thought it was just my R107 lighter socket being worn out. I removed the ashtray and installed a plate with three outlets wired into the original circuit.
Current:
Monika '74 450 SL
Gone:
Rudolf ‘86 300SDL
Bruno '81 300SD
Fritzi '84 BMW
'97 Jeep GC
'96 Volvo 960
'96 Impala SS
'74 Jeep CJ5
'71 Buick GS conv
'67 GTO conv
'63 Corvair conv
'57 Nomad
JN74SL is offline
post #7 of 17 (permalink) Old 05-02-2014, 11:19 PM
Jackpody's Avatar
Quoted: 12 Post(s)
Does fit if you nudge it gently in there, though! I've never had a plug fall out while driving, but I do see how it could be an annoyance, haha.
Jackpody is offline
post #8 of 17 (permalink) Old 05-05-2014, 02:24 PM Thread Starter
I put the GPS into the cigarette outlet and it didn't work. Now I notice that the dash lights all went off and won't turn on at night.
I guess it did blow a fuse then.
post #9 of 17 (permalink) Old 05-06-2014, 12:52 AM
Jackpody's Avatar
Quoted: 12 Post(s)
There's something deeper wrong with your wiring then. If the normal cigarette lighter works but a GPS won't, then I have no clue at all. Did it blow instantly or did it take time? Grasping straws because I genuinely do not know how that is possible.
Jackpody is offline
post #10 of 17 (permalink) Old 05-06-2014, 12:56 AM
Scoot's Avatar
Quoted: 115 Post(s)
The cigarette lighter socket is not the standard size that the GPS plug is. It is possible that the GPS plug shorted out the cigarette lighter and blew the fuse.
Scoot is offline
