W108 4.5 oil change - Cooler??? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-29-2014, 10:31 AM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
Quick poll. Those of you with the 4.5 in a W108, do you drain the cooler at every oil change or do you just do the pan/filter? My maintenance manual from MB does not say to drain, but I know it retains about a half to a quart of oil.
Just curious.
BTW, I use 20W50 in the summer in my benz. I run Castrol.
TZ_280SEL is offline
post #2 of 5 (permalink) Old 04-29-2014, 11:33 AM
Peoria Benz's Avatar
Date registered: Jul 2006
I usually do, but on my current car, the threads were messed up when I bought the car, so I am leaving better off alone. As you said, it is maybe half a quart. And I don't drive that many miles, so the oil isn't that dirty, just time to be changed.
Peoria Benz is offline
post #3 of 5 (permalink) Old 04-29-2014, 01:13 PM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 88 Post(s)
Pan drain plug and filter replacement only. If a connection isn't leaking there's usually no point in disturbing it; and there isn't that much oil remaining in the cooler to make it worthwhile.
ejboyd5 is offline
post #4 of 5 (permalink) Old 04-29-2014, 04:07 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
On my 220d I would always drain the oil cooler - the oil filter kit comes with the filter, the ring for drain plug, o ring for the filter and 2 smaller rings one for the bolt that holds the filter on and one for the cooler plug.
But I wouldn't obsess over it.
Sent from AutoGuide.com App
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #5 of 5 (permalink) Old 04-30-2014, 09:19 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
no need to .
agillot is offline
