trans. adjustments on 1976 300D - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-19-2014, 05:55 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1976 300SD, 1995 E300D
The car is a 115114 12 037979 model. The transmission number is 123 270 12 01 000 36
I have a manual but my computer won't load it for some reason. I'm wondering what the procedure is for adjusting the bands. There is no Bowden cable or vacuum on this transmission.
Thanks for any info.,
Gus
2_300_D is offline
post #2 of 11 (permalink) Old 04-19-2014, 08:29 PM Thread Starter
OK something that may shed more light on this problem. In the fuse box is a fuse for an electronic automatic transmission adjustment????? Also there IS something with four wires going to the tranny where it looks like the modulator would be if it had one. This thing must be some kind of morphodyte or something. Good car though I've had it for years. Just need to get it transmissioning again
2_300_D is offline
post #3 of 11 (permalink) Old 04-20-2014, 01:24 PM Thread Starter
OK, guys I got it.
Drained a little fluid out and put in some conditioner. Took her for a drive and it got better and better. Next thing on the agenda is a filter and fluid change. She's been sitting awhile since I bought my 95 E300D I suppose she's gummed up.
2_300_D is offline
post #4 of 11 (permalink) Old 04-20-2014, 02:37 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
So, is it a manual or an automatic? I can't make heads or tails of what you're saying, and I have two college degrees.
flyboyike is offline
post #5 of 11 (permalink) Old 04-20-2014, 03:01 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1473 Post(s)
I assume he's wondering how upshift timing (bowden) and shift quality (vacuum modulator) are handled on the earlier automatic transmissions, which apparently lack these external features. The use of the term manual in the OP is a bit confusing, since he's referring to the FSM vs. a manual transmission. I'm only familiar with 722.3 and 722.4 transmissions, so I can't provide any direct assistance.
Zeitgeist is offline
post #6 of 11 (permalink) Old 04-20-2014, 03:15 PM
flyboyike's Avatar
Quoted: 68 Post(s)
The transmission number he gives also makes no sense.
post #7 of 11 (permalink) Old 04-20-2014, 05:02 PM
Cruise Control
Zeitgeist's Avatar
I assume that number is just the MB part number for the actual transmission case, and not the model number
post #8 of 11 (permalink) Old 04-21-2014, 07:22 AM Thread Starter
Sorry for the confusion!
I apologize for the misunderstanding. It is an automatic. I guess I assumed the transmission number would be enough information for anyone interested or with any suggestions. Again, I apologize.
It is working now; actually it is working quite well. This is the first time I've ever used one of those miracle juice cures. Quite honestly I've not been a believer but . . .I guess the results are hard to argue with!! All in all the transmission now acts bullet proof. First to second, second to third are crisp third to 4th is smooth with no flare or slippage.
As to the number I referenced in the original post; the first number is the serial number on the car the latter is the number stamped on the lip just above the pan on the right (passenger) side of the transmission.
I am still interested in any information on these older transmissions without a Bowden rod or vacuum modulator. It seems a little odd for a transmission in a car made in 1976.
currently:
76 300D (British red)
95 E300D (metallic charcoal)
2_300_D is offline
post #9 of 11 (permalink) Old 04-21-2014, 07:31 AM Thread Starter
I now believe this wiring has something to do with the kick down but I'm not entirely sure. I'm still hoping someone can shed a little light on this.
currently:
2_300_D is offline
post #10 of 11 (permalink) Old 04-22-2014, 03:45 PM Thread Starter
nobody knows anything about these transmissions in this cross over year huh?
currently:
2_300_D is offline
