220 SEB Coupe 1964 W111 engine problem - Page 2 - Mercedes-Benz Forum
post #11 of 22 (permalink) Old 04-20-2014, 12:45 PM Thread Starter
Date registered: Apr 2012
Vehicle: Land Rover with retrofitted MB 300 D engine; 617.910, 220 SEB Coupe 1964
Thanks, I will try to find the fuel pump repacement thread.
Also I think I will go with an aftermarket fuel pump. Building a shield and brackets is no big deal for me.
I have a couple of separate questions as well though;
A) The crankhouse ventilation on my car is simply a tube from the valve cover to open air at the lower part of the left hand side of the engine. Is this correct?
B) The electrical system is powered by a dynamo. Obviously alternators are more effective. Any special issues with replacing the dynamo with an alternator? I assume just bypassing the voltage regulator to the battery. (I realize purists may shudder at this but driving cars must be practical as well.... :-))
Lajodi is offline
post #12 of 22 (permalink) Old 04-20-2014, 09:38 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
These are medium pressure pumps 16-18 psi.for w111 se
adler is offline
post #13 of 22 (permalink) Old 04-20-2014, 10:24 PM Thread Starter
Thanks Adler,
I found the thread on fuel pump replacement.
http://www.benzworld.org/forums/vint...fuel-pump.html
It seems that the author there was successful using a Facet pump. That thread mentions 6 psi and 3,3 liters per minute (without being certain). Can I confidently go with the 16-18 psi mentioned above? Anyone able to confirm the flow rate of the pump?
Lajodi is offline
post #14 of 22 (permalink) Old 04-20-2014, 11:52 PM
Quoted: 59 Post(s)
Its. 6 psi and 3.3 litres per minute is the correct specs for a 220se and the230sl Models.
adler is offline
post #15 of 22 (permalink) Old 04-21-2014, 04:29 AM
wbain's Avatar
Date registered: Dec 2003
The crankcase vent line should be routed to a hose coupling on the throttle body. There is a specific rubber coupling for this. I'll take a pic of it on my car and post it and the number.
The fuel pumps are rebuild-able. Please straighten out the bottom of the shield protecting the pump. Get new fuel pump buffers/mounts as needed. Renew the fuel hoses including the short coupling hoses by the center driveshaft bearing. Grease the sliding joint on the rear driveshaft and grease the front driveshaft coupling after the trans.
wbain is offline
post #16 of 22 (permalink) Old 04-21-2014, 06:39 AM
wbain's Avatar
Here is a picture. No number yet.
wbain is offline
post #17 of 22 (permalink) Old 04-21-2014, 10:20 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 93 Post(s)
Sometimes an inefficient pump can be resusitated by switching the positive and negative leads and running the pump in reverse using diesel fuel as a cleaning medium. Always worth a try before springing for the big $$.
ejboyd5 is offline
post #18 of 22 (permalink) Old 04-21-2014, 05:49 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
there is a screen in the inlet pipe of pump , it does plug up .easy to check .
agillot is offline
post #19 of 22 (permalink) Old 04-22-2014, 01:46 AM Thread Starter
Thanks all following this and helping. All noted on rebuilding the pump, I am sourcing parts just now.
Looking closely at the impeller (see attached pics) I note that one side of the teeth are slightly rounded, -I assume these should be facing the inside of the pump, correct? And the sharper edges towards the bottom plate...
Then we have the key arrangement. The shaft has longitudinal groove which is the obvious "locking" groove for the key, but on the opposite side is a recess as well. What is the function of that? See pics attached.
Thanks for the photo on the crank-case vent, this is next to be checked up on.
Name:	Impeller and shaft.jpg
ID:	903033   Click image for larger version
Name:	Impeller close up.jpg
ID:	903041   Click image for larger version
Name:	Shaft close up.jpg
Lajodi is offline
post #20 of 22 (permalink) Old 04-22-2014, 08:38 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
To your question about the dynamo, yes you can and probably should switch to an alternator, very common upgrade on these cars and if you're driving more than showing it really makes sense... plus, you can switch back at any time if needed.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
