280 6cyl or 280 v8? - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 04-18-2014, 07:57 AM
wbain's Avatar
Date registered: Dec 2003
If you buy the 6 cyl, be aware that at 60 mph the engine will run about 3000 rpm. Don't worry, the engine is made to do this. If the engine, and trans, mounts are new it will be quite. Don't change out the rear axle because the acceleration will slower. As long as the engine has been properly serviced it will last many more years. Clean gas and filter changes will ensure long injection pump life.
Check out the 230-250-280SL web site, www.ssl113.org as the 280SL used the same engine and the others the same style injection system.
wbain is offline
post #12 of 20 (permalink) Old 04-18-2014, 08:33 AM
DR.EUROCAR's Avatar
Date registered: Apr 2014
Vehicle: Mercedes
Quoted: 5 Post(s)
In that car owned a 280 6 cyl and 280 V8 3.5 I prefer the 6 cylinder, as it is about 1/2 cost to maintain. And in my opinion the power difference is marginal at best between the fuelie 6cyl and v8. I replaced a set of trigger points, updated to electronic ignition and replaced a map sensor on my v8 in a month and realized I had just thrown a good week worth of European vacation at the car and increased the cars value by $0.00..
For cruising a well maintained 6 cyl is okay. Remember Mercedes built the cars knowing they might be at max rpm all day as it was and still is possible to do so in Germany and Italy and I am told parts of Austria.
6 cylinder car will be much cheaper so you can get a nicer car for crap v8 car money...
Wanted:
w126 Left euro headlight, Someone that can refinish my wood in Grey woodgrain
Helpful Positive responses, Negativity Keep quiet
DR.EUROCAR is offline
post #13 of 20 (permalink) Old 04-18-2014, 03:34 PM
Jackpody's Avatar
Date registered: Oct 2012
Vehicle: Mercedes Benz W108 - 280 SE (1970) / Mercedes-Benz W123 200T (1983)
Quoted: 12 Post(s)
I'd go for a six cylinder as well. They are easier to DYI, the fuel injection is mechanical (electronic on the V8's are cool and everything, it's just a bit harder to diagnose problems and old wiring is rarely good if you buy a car that's been sitting!), the nose is a tad lighter and it's very rev happy. It is a bit louder at highway speeds but it has plenty of grunt, it loves the highways.
I'd go for one with a manual. I've never actually been in a W108 automatic, so I cannot tell you my exact experience. I have been told that the automatics feel a lot slower than the manuals though, and I can believe that.
Jackpody is offline
post #14 of 20 (permalink) Old 04-19-2014, 11:50 PM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Well guys i pulled the trigger today and went for the 6 cylinder.
It is in superb condition. The family are the original owners from 1968.
always garaged and covered with a sheet. Original paint has gloss and depth, seats no tears or rips and very comfy. Dash perfect, this thing is like a time capsule. I drove it 4 1/2 hrs home on I5. Yes it is a little louder than the v8 at high speed. But i found once it settled into around 70 to 75 it felt great.
It is a real 60k car.It feels tight all round. He showed me receipts for work done.t 54k it had a new tranny fitted the original was sitting so long without use it gave him problems. I could not be more happy with it.
Thanks to all of you for the help in buying a 108. I'm sure i'll be a regular visitor to this site for tips on how to keep this car in top notch.
One question i do have. Do you guys add an lead additive to the fuel when filling up? and i assuming high grade 92.
Thanks John.
wroding is offline
post #15 of 20 (permalink) Old 04-20-2014, 12:19 AM
Jackpody's Avatar
Quoted: 12 Post(s)
Congrats! it sounds like a lovely car (post pictures!)
There's another thread here where lead additive is being discussed, it's still on the first page of this sub-section.
To sum it up, some people say it's not needed and some say it's a good idea to use. If you bought a six cylinder with fuel injection, then I'd use a lead additive. It lubricates the insides of the MFI pump and will give it a longer life. It also lubricates various other parts that wouldn't get lubrication with normal fuels too.
I run a 280 SE W108 and I was told to use a lead additive in it because of the above reasons. You cannot really go wrong with it as it'll just go through the engine and come out as exhaust smoke if it's not needed.
Jackpody is offline
post #16 of 20 (permalink) Old 04-20-2014, 12:25 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Here is the craigs list posting. http://sfbay.craigslist.org/eby/cto/4413136478.html
i will post more in the next few days once i wash all the bugs off from the blast down the highway
Thanks for the advice on the additive.
Cheers john.
wroding is offline
post #17 of 20 (permalink) Old 04-20-2014, 06:35 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Looks great, congrats!
flyboyike is offline
post #18 of 20 (permalink) Old 04-20-2014, 03:49 PM
Jackpody's Avatar
Quoted: 12 Post(s)
Cheers john.
Here's the thread on the lead additive discussion
http://www.benzworld.org/forums/vint...ubstitute.html
I'd consider reading it and for you to consider everything posted there (especially the article I posted!). I've been running the Shell additive I posted in there with no problems at all and I'm sure the fuel system is being lubricated.
Jackpody is offline
post #19 of 20 (permalink) Old 04-21-2014, 07:48 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks Jackbody
i will read that thread.
here are some pix of me picking up my new baby.
Name:	IMG_7063 (1024x768).jpg
ID:	901561   Click image for larger version
Name:	IMG_6979 (1024x768).jpg
wroding is offline
post #20 of 20 (permalink) Old 04-21-2014, 10:28 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
I do have a couple of questions.
I notice the shifting of the transmission is a little jerky. 2nd to 3rd. 3rd to 4th.
From the receipts the transmission is 5k miles old. The guy told me when it was fitted he noticed that it was a little jerky shifting from new.
i was wondering if it could be a vacum leak of some kind? Any ideas would be welcome.
Also because the dash is in such nice condition i would like some advice on care. i do know that products such as armor all tend to do more harm than good.
i was thinking just a lightly dampened rag would be best for cleaning.
Also does anyone sell a fitted protective cover for these cars?
Thanks guys.
john.
wroding is offline
