cylinderhead warpage 130 engine - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-15-2014, 08:49 AM Thread Starter
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Wondering if anyone has had issues of warpage on the manifold side of the cylinder head or if it is also liable to warp when the engine overheats .
Ad
adler is offline
post #2 of 11 (permalink) Old 04-15-2014, 09:22 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
no , never seen that .
agillot is offline
post #3 of 11 (permalink) Old 04-15-2014, 05:10 PM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
I am rebuilding the engine as we speak but to have warpage on the side of the manifold on the head sounds very unusual as it is almost impossible to warp the head sideways.
How do you know you have warpage? what makes you think that is the case?
here is a pic of my M130 head afte rebuild for comparison.
ID:	891361   Click image for larger version
ID:	891369   Click image for larger version
kavadarci is offline
post #4 of 11 (permalink) Old 04-15-2014, 06:02 PM Thread Starter
Quoted: 59 Post(s)
As a overheated head warps it takes up a bow shape around the centre area,this may effect the central area of the manifold side as it too moves up the same amount.
Refacing trues up the gasket face by cutting up the end areas to level the bowed up centeral portion .
My question was if the manifold area ever requires a similar correction as it too will be bowed inwards/up at the centre portion.
Ad
adler is offline
post #5 of 11 (permalink) Old 04-15-2014, 06:17 PM Thread Starter
Quoted: 59 Post(s)
Kavadarci.
I have a spare 130 engine .it runs lean and spits back , I have systematically substituted the distributer as well as the manifold with carbs from a good engine to isolate the fault ,lean condition remains though the engine runs for extended periods . Even the Valve timing checked using degree wheel.still lean spitting.
adler is offline
post #6 of 11 (permalink) Old 04-15-2014, 07:49 PM
Luna Gaudi's 72 250's Avatar
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Kav, I would love to see you take some artistic photos of your M130 engine. For example some shots that could be printed on a tshirt. That head with the valves looks amazing.
Luna Gaudi's 72 250 is offline
post #7 of 11 (permalink) Old 04-15-2014, 08:14 PM
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Luna,
That would be your expertise; I'm not that good at artistic stuff as you.
Adler,
It sounds you have done more extensive troubleshooting that most of us would do.
I'm very doubtfull that warped head on the manifold side can cause what you are describing but I am not rulling out either. It must significant warpage, visual to the eye to do something what you are describing.
Have you looked at the timing chain? Few members have had timing chain worn to a level that would offset the engine timing.
Just a thought.
post #8 of 11 (permalink) Old 04-16-2014, 08:58 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
if head was warped a bunch [ like 12 th ] you have to shim the cam towers at the end [ easy to do ]
agillot is offline
post #9 of 11 (permalink) Old 04-16-2014, 09:52 AM Thread Starter
Quoted: 59 Post(s)
Very slight difference at the ends and cam pedestals correctly shimmed ,valve timing checked with degree wheel, dial indicator per manual ,slight stretch corrected with offset woodruf key.
Ad
adler is offline
post #10 of 11 (permalink) Old 04-16-2014, 12:18 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
My cylinder head is being rebuilt currently and the shop told me they do have to hone the manifold itself to seat against the new head, maybe this is your case and you're interpreting it as a warped head on the side?
@Luna I got pics of my new head once it arrived in the shop and I thought the same thing. I plan on using my old head (not viable as a core) for some sort of art project also.
kavadarci likes this.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
