Just Bought A W114 - Page 8 - Mercedes-Benz Forum
post #71 of 139 (permalink) Old 05-08-2014, 08:19 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 113 Post(s)
i have a weber conversion kit for that motor somewhere in the shop that I'm saving for that special 250C that comes up.
Front and rear sub frame on that car is the same as your SLC.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #72 of 139 (permalink) Old 05-09-2014, 04:48 AM Thread Starter
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 104 Post(s)
I've read that the Webers are the way to go. That is a mod that I have on my list, but it will have to wait for awhile. There is a guy here that is a whiz with carburetors and he will rebuild both my Zeniths for $300, if needed, so I may have to do that. Switching to Webers is way out of the budget in the near future. If you have any spare Zenith Carburetor linkage for sale please let me know.
I thought about saving the '74 SLC drivetrain for this car, just in case, but I offered the car to someone at Keels and Wheels so it will probably be gone soon. I need the space more than I need the car.
dgosh28 is offline
post #73 of 139 (permalink) Old 05-09-2014, 05:00 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
I bought the Weber Redline kit for my 114 years ago. It came fully loaded - adapter plate, etc. The car ran just fine too though I had issues with setting the choke properly.
Grubeguy is offline
post #74 of 139 (permalink) Old 05-10-2014, 04:52 PM Thread Starter
dgosh28's Avatar
Quoted: 104 Post(s)
Found out today that there will be a swap meet at the annual Texas cruise to Centerville. Maybe I will find some carburetor linkage.
Probably out to take a few things to sell as well.
dgosh28 is offline
post #75 of 139 (permalink) Old 05-10-2014, 06:42 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1797 Post(s)
In about a week or so, I should have decided which will be the parts car, and have some linkages for you.
Sent from AutoGuide.com App
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #76 of 139 (permalink) Old 05-11-2014, 04:10 AM Thread Starter
dgosh28's Avatar
Quoted: 104 Post(s)
Thanks Fonzi. I appreciate the help. BTW, I was invited to join the board of the local MBCA section yesterday. I accepted. Hopefully, I will be able to increase the membership and participation of the classic/vintage owners.
dgosh28 is offline
post #77 of 139 (permalink) Old 05-15-2014, 10:42 AM Thread Starter
dgosh28's Avatar
Quoted: 104 Post(s)
If anyone knows how to get the metal plate off the steering column, behind the horn pad, please let me know. I removed the 4 Allen bolts, but it won't budge.
dgosh28 is offline
post #78 of 139 (permalink) Old 05-16-2014, 06:47 AM
Fonzi's Avatar
So you've got the car now running off fuel from the gas tank. So your fuel, air, and spark are all working (close enough to) correctly, and now you are doing what you can to figure out a way to fix the transmission shifter linkage. Right?
And you are trying to figure out why the column shifter won't move. Right?
My signature:
Fonzi is offline
post #79 of 139 (permalink) Old 05-16-2014, 01:28 PM Thread Starter
dgosh28's Avatar
Quoted: 104 Post(s)
After putting a scope in the gas tank we were able to see that it was surprisingly clean. I added about 4 1/2 gallons of fresh Super Unleaded to the tank, changed the fuel filter, and the rubber fuel line on both sides of the filter. The car idles great, but the rear carburetor leaks fuel pretty bad once the bowl fills so I can't run it long. The problem I have now is the shifter will not shift from park no mater what I do. I planned to remove the column, but would like a better solution, if anyone has any ideas.
dgosh28 is offline
post #80 of 139 (permalink) Old 05-16-2014, 01:31 PM
Vehicle: 1972 280CE
Quoted: 113 Post(s)
Have you looked under the car to see if the linkage is not bent up. You may also want to try disconnecting the linkage from the trans to see if it will suddenly free up.
With best regards
Al
alabbasi is offline
