Just Bought A W114 - Page 7 - Mercedes-Benz Forum
post #61 of 139 (permalink) Old 05-01-2014, 04:03 AM Thread Starter
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
A little advice needed. Should I put the donor carbs with the linkage/ wiring on the car and see if it will run that way, or attempt to transfer the wires and linkage to the carbs that are on the car currently? I have no idea really of the condition of either.
dgosh28 is offline
post #62 of 139 (permalink) Old 05-01-2014, 06:04 AM
Date registered: Sep 2010
Vehicle: 1976 300SD, 1995 E300D
I'd see if the current set is actually pumping gas before I took them off. If it will run long enough to pump the bowls full; check to see if they are pumping gas. With the car shut off just stick your head over the carbs. and run the linkage; you should be able to see the jets pumping. Unless the linkage is completely gone. If that is gone it may be simpler to put the other carbs on.
currently:
76 300D (British red)
95 E300D (metallic charcoal)
2_300_D is offline
post #63 of 139 (permalink) Old 05-01-2014, 06:36 AM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
You hit the nail on the head. The linkage AND the wiring are missing. I was looking for linkage and got a deal on the whole setup, with carbs, so I bought that instead. As for the fuel, sometimes I think I hear it spraying, but can't see any visually. Looks like I better swap the carbs.
dgosh28 is offline
post #64 of 139 (permalink) Old 05-01-2014, 10:10 PM
93SoCal400E's Avatar
Date registered: Jul 2008
Vehicle: 2005 CLK500 w/23K !
Quoted: 37 Post(s)
I think you are referring to the accelerator pumps.
The jets are typically in the venturis and don't have fuel flow unless air is going through and creating low pressure.
In any case, working accelerator pump is somewhat of a good sign, but as I have pointed out, the guy pulled this into a field to fix SOMETHING in these carbs and didn't finish. After which 2 years of dirt and dust and moisture into open fuel lines and carbs. So replacement ones are a better shot.
93SoCal400E is offline
post #65 of 139 (permalink) Old 05-02-2014, 05:14 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1673 Post(s)
How hard is it to remove a wiring harness from one of these cars?
I'm wondering if I should part out my 250 now.
My carbs need accelerator pump work because the car sputters at acceleration, but otherwise, it's running well.
Some things I think you could use:
- wiring harness
- my carbs, linkage, etc
- shifter column
- ignition and a full set if matching locks, and the datacard and full knowledge of the car they come from.
Sent from AutoGuide.com App
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #66 of 139 (permalink) Old 05-02-2014, 06:39 PM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
- wiring harness
- shifter column
I hoping that the shifter column problems is just a pin that is stuck or something simple. If you see the condition of this car's interior and the condition of the engine bay you would think it was two different cars. A couple of hours spent cleaning the interior and it will look like a million bucks.
Looks like I won't get to work on the car before Monday though. I work tomorrow and Keels and Wheels is Sunday. Maybe I will get to meet Wayne Carini. I am dying to get his opinion on the future desirability of the 107026.
dgosh28 is offline
post #67 of 139 (permalink) Old 05-05-2014, 06:52 PM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
Got a chance to work on the car a bit this morning. Actually was able to make it idle for a couple of minutes. The replacement carbs I bought were only able to donate one linkage rod. I still need the long one with the two adjustment nuts, if anyone has one for sale.
dgosh28 is offline
post #68 of 139 (permalink) Old 05-07-2014, 02:33 PM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
Some pics of the seats after I spent some cleaning them with some Mother's VPL cleaner. Slowly getting it into shape.
ID:	932433   Click image for larger version
ID:	932441   Click image for larger version
ID:	932449   Click image for larger version
dgosh28 is offline
post #69 of 139 (permalink) Old 05-08-2014, 06:22 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 109 Post(s)
Dan
You need to bring that to Centerville.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #70 of 139 (permalink) Old 05-08-2014, 09:15 PM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
Originally Posted by alabbasi View Post
Dan
I REALLY want to, but looks like I won't have it ready in time. Still missing some carburetor linkage, need to pull the tank and make sure it is clean, and the steering column has a problem. The shifter won't shift out of park. Those are just the immediate needs and I probably won't get to spend more than 2 or 3 hours on the car in the next week, if that much. The plan at the moment is to drive the 380SLC 5.6. I haven't driven it that far before so it would be a good outing, if the climate control doesn't act up again.
dgosh28 is offline
