Leaking Servo - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-08-2014, 09:03 PM Thread Starter
Date registered: Dec 2012
Leaking Servo
My servo is leaking coolant. I reconnected the hoses and hoping I did not crack it by connecting them wrong.
How are the hoses connected, does anyone have a diagram?
Also is there a way to remove this thing and still have A/C in summertime?
Thank you and please help!
Dayminder is offline
post #2 of 10 (permalink) Old 04-09-2014, 06:03 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 478 Post(s)
Please post what car you have.
coolant and AC have nothing to do with each other. what do you mean by "servo"
can you post a picture?
rumb is online now
post #3 of 10 (permalink) Old 04-09-2014, 07:49 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
what model of car ?????
agillot is offline
post #4 of 10 (permalink) Old 04-09-2014, 08:40 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
What you can do is bypass the servo and run the hose from the aux water pump directly to the heater core. You can then install a shut-off valve on that hose to block the coolant in the summer. If the servo is otherwise functional, then yes, you will still have A/C in the summer.
There are also now reman sevos available for relatively reasonable money.
Mercedes Benz Climate Control Servo | eBay
flyboyike is offline
post #5 of 10 (permalink) Old 04-09-2014, 08:42 AM
flyboyike's Avatar
Quoted: 69 Post(s)
He is talking about the infamous old-style ACC servo, in which the coolant and the A/C very much did have something to do with each other. Said servo was seen in 107, 116 and early 123 cars.
post #6 of 10 (permalink) Old 04-09-2014, 06:30 PM
Premium Member
Quoted: 59 Post(s)
Premium Member
connect the 4 hoses the same way as they are on the servo with 2 pieces of pipe / clamps .now , the heater is on all time , install a shut off valve at the hose that is at the rear of head [ left rear ] now , if you tell me what model the car is , there is a way to install a 190e heater valve , so you will have remote control without butchering the car .
agillot is offline
post #7 of 10 (permalink) Old 04-20-2014, 06:54 PM Thread Starter
Thanks. I cut off the supply of coolant to the servo. Now I have no heat (no problem with that) but not a leaky servo to cause an overheated engine.
post #8 of 10 (permalink) Old 04-20-2014, 07:55 PM
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
There is an aluminum bodied servo available, if you want to keep the factory look, or you can order the Unwired Tools replacement. UnwiredTools, LLC.
It has the reputation of being more trouble-free. I replaced my cracked, but working, servo in the 1981 380SLC 5.6 with the aluminum replacement and it functions well, most of the time. I also purchased the Unwired Tools product, but I haven't installed it yet. I plan to keep it as a backup in case the aluminum bodied servo fails.
dgosh28 is offline
post #9 of 10 (permalink) Old 04-21-2014, 03:44 PM
Date registered: Jul 2008
Quoted: 348 Post(s)
You need to understand the chain of events that lead to the acc system not working. The cracked servo is an obvious problem....and should be replaced..
Typically what happens to the system, is the aux water pump freezes, burns up the amplifier and then kills the small motor in the servo....there is also a foam sensor tube that crumbles to dust.
cooljjay is offline
post #10 of 10 (permalink) Old 04-21-2014, 04:36 PM
dgosh28's Avatar
Quoted: 103 Post(s)
What would cause the heater to come on all by itself even though the temperature dial is set to 65?
dgosh28 is offline
