Anyone else hear of this? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-02-2014, 04:34 AM Thread Starter
Premium Member
MadColonel67's Avatar
Date registered: Dec 2012
Vehicle: 2004 E500 4Matic Wagon, 1980 450SLC, '94 SL500
Quoted: 14 Post(s)
Premium Member
A fellow Finnie owner asked me if my '67 230S had this ground wire attached to the radiator. His technician explained its purpose:
Attached is the picture of the ground wire grounding the radiator. Klaus explained to me today that since the radiator is copper and the head is aluminum there is a current or a charge that builds up that will sear the pistons. The fix is to the ground as pictured and my radiator actually had a small clip that it attached to.
Should I be worried I don't have this?
MadColonel67 is offline
post #2 of 5 (permalink) Old 04-02-2014, 05:58 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
uh, no.
there is corrosion between aluminum heads and iron block. good antifreeze slows this down.
sounds like the original engine ground is missing and this was the easiest place for a lazy mechanic to put back.
rumb is offline
post #3 of 5 (permalink) Old 04-02-2014, 07:09 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
I think my 1968 280S W108 had a ground wire there. I never knew why.
Scoot is offline
post #4 of 5 (permalink) Old 04-02-2014, 07:59 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
yes , all the older cars had this , this was to prevent electrical voltage to be present in cooling system that would result in galvanic ???? corrosion in engine block / head .the radiator has rubber strips on each side , this would insulate it from frame , but on the other hand the 6 bolts goes thru .
agillot is offline
post #5 of 5 (permalink) Old 04-02-2014, 10:04 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Never mind any of that, what's with the Moskvitch 412 in your avatar?
flyboyike is offline
