220SEB Cabriolet - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 06-11-2014, 12:39 PM Thread Starter
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1469 Post(s)
I'm finally getting around to working on this car next week, and have a quick question. Apparently it has a miss in one cylinder, so I need to run a compression check after adjusting the valves. I've never played with an M127 before, but is it possible to cobble together a DIY tool for valve adjustments, vs buying the factory crows foot? Valve Adjustment Tour
Zeitgeist is offline
post #12 of 12 (permalink) Old 06-12-2014, 06:57 AM
DR.EUROCAR's Avatar
Date registered: Apr 2014
Vehicle: Mercedes
Quoted: 5 Post(s)
Originally Posted by agillot View Post
the spring kit number is 900 329 05 01 .if you cant find a new one [ used to be $ 50 ] get a used one .test the injectors , they are pricey if you can find them [ 619 421 3254 ] in san diego .
+1 fuel injectors are expensive and usually they are good. I would pull them out and clean.
You need the tool in the pic to clean the injectors. I usually use diesel or ATF and have even saved injectors on cars that sat over 10 years...
Wanted:
w126 Left euro headlight, Someone that can refinish my wood in Grey woodgrain
Helpful Positive responses, Negativity Keep quiet
DR.EUROCAR is offline
