3.5 V8 valve adjustment m116 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-14-2014, 04:35 PM Thread Starter
Pizing82's Avatar
Date registered: Jun 2013
Has anyone out there carried out or know how to carry out a valve adjustment on an m116 3.5 v8.
The large nut (possibly the lock nut is very tight so i just want to check the process.
The other thing that would be handy is which valves to adjust on whether cyl 1 on TDC or 5 on TDC to speed up the process.
Thanks in advance if you can help out.
Pizing82 is offline
post #2 of 3 (permalink) Old 03-15-2014, 06:06 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1573 Post(s)
Assuming the process is the same as the m117 d-jet 72-73 450sl, I'm not sure what the question is. I didn't think it mattered where you started because you crank the engine to get each cam lobe where you want it to be able to measure the gap / valve clearance.
Then again, I decided not to adjust my 1973 because the numbers weren't too bad and I wasn't getting perfectly consistent readings when I tried to prep to adjust my valves. I did buy the hazet tool for this job though.
Sent from AutoGuide.com App
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 3 (permalink) Old 03-15-2014, 07:59 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
See if these attachments help.
Baybear is offline
