Help with SL 450 W107 1980 - car chocking at 2'000 rpm - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-08-2014, 11:42 AM Thread Starter
olszowa12's Avatar
Date registered: Aug 2007
Hi Guys,
I'm new here although I created an account some time ago.
I am more active on the other forum in the C63 AMG section.
I am coming here to seek help about a problem of my best friend's 1980 SL 450.
The car runs perfectly when idle. Repairs done so far:
- new fuel system
- new fuel pump
- new fuel lines
- no unwanted air coming in or out in the air intake
The problem is the following - increasing the throttle to 2'000 rpm the car chokes, spits, shoots and dims.
We are guessing there is a problem with the K-jetronic injection. Any ideas what can be the cause ?
Any input will be greatly appreciated!
Thanks in advance.
P.S. Threads without pics are useless so here are three
olszowa12 is offline
post #2 of 4 (permalink) Old 03-09-2014, 03:56 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
check fuel pressure 1 st , and us car 1980 has a oxy sensor / ecu .remove air filter housing , and see if frequency valve buzz with engine running .if it does not , you need to test the pink relay around fuse box [ early voltage protection relay .] .with air filter off , does the air flow plate moves downward while accelerating , and if you help with your finger , will engine accelerate . when did this started .
agillot is offline
post #3 of 4 (permalink) Old 03-12-2014, 02:00 PM
Date registered: Jan 2014
Vehicle: 1975 240D
What do you mean by chokes, spits, shoots and dims? Is it stalling and backfiring? Is it doing this at 2000 rpm under load or just sitting?
Just Another Dave is offline
post #4 of 4 (permalink) Old 03-12-2014, 08:22 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1571 Post(s)
The r/c107 forum is pretty active. I am going to guess maybe a fuel delivery issue, but I don't know.
Sent from App
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
