Where to start? - 1971 250 w114 m130 zenith carbs - Page 9 - Mercedes-Benz Forum
post #81 of 138 (permalink) Old 02-18-2015, 05:36 PM Thread Starter
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1679 Post(s)
I stole a few more minutes to mess with the car. Knowing the last time I was at the car I couldn't even get it to start when I first tried, my expectations are low. I did have it to the point where I was able to drive it around the block, but I screwed it all up since then, and will need to start over. I didn't have too much time, so just cranked it up:
- linkage between carbs disconnected so they can be tuned independently for idle.
- squirt each of the accelerator pumps 1-2 times
- press remote starter button. Run. Stall.
- I could see that the front choke was too far open so I rotated the housing and started the car. It was running. Choke wires were disconnected. Hmm...
- while running, I connect choke wires with the aftermarket setup of both chokes together (not the maybe original rear choke wire I think I found).
http://youtu.be/_PgNa6ewBVo
- Within less than a minute the chokes were too wide open and it was starting to stall. Hmm... Must be too lean. (Don't bother to think much about that vacuum leak. Right? Nope.).
- disconnect choke wires and have to adjust housing to keep it from stalling. (Oh... Now I know why I was running too rich later... Keep reading if you care.)
- so I start messing with all the million adjustments: idle mixture screw, small throttle linkage, stop screw, and even the choke housings (which I didn't think too much about the gradual cooling due to lack of electric).
- the idle was really sensitive to the choke position, and I could have stalled it easily by tilting either of them by hand. Hmm... Why so sensitive? Maybe bad idle mixture screw setting?
- the exhaust started getting really smokey. Too rich obviously. But when I opened either choke plate manually, idle would slow. Hmm...
- finally it stalled and I called it quits.
I took this picture of the temp after it stalled. I am pretty sure oil pressure was always good.
Where to start? - 1971 250 w114 m130 zenith carbs-imageuploadedbyautoguide1424306075.641622.jpg
I know it's not much, but in trying to tune these, I think it is good to record everything as best as possible.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #82 of 138 (permalink) Old 02-18-2015, 07:13 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 463 Post(s)
Correct way to start car is depress pedal slightly to set chokes/fast idle.
then turn key until starts. no pumping of pedal.
Hot starts hold pedal to floor, do not pump at all and crank till starts.
is your idle adjust screws set to 2.5 turns initially? when cold are both choke plates closed or mostly closed? did you see the test on cold engine just turn key on and in 2 minutes the chokes should open up.
I know you are just trying to get it to run. can you get it to a point where it will warm up and idle?
adjust choke just enough so you can get engine running and idling.
Then do you balancing and idle speed settings with the little turnbuckles.
rumb is online now
post #83 of 138 (permalink) Old 02-18-2015, 07:26 PM Thread Starter
Fonzi's Avatar
For simplicity, I will respond in all caps. It's not yelling.
[QUOTE=rumb;11389962]Correct way to start car is depress pedal slightly to set chokes/fast idle.
I AM STILL STARTING WITH REMOTE STARTER. NEVER QUITE FIGURES THAT HALF PEDAL THING OUT YET.
IT SEEMS THAT THE CAR STARTS MUCH EASIER WITH A SQUIRT.
MY SEDAN SEEMED TO START WITH A TWIST OF THE KEY ONCE WARM. IM CLUELESS
I AM ASSUMING YOU MEAN THE IDLE MIXTURE NEEDLE SCREW IN BASEPLATE. RIGHT? THATS ABOUT WHERE IVE HAD IT BUT I MESSED WITH THEM LIKE NUTS TOO,
YES
I DID SEE THAT. I DIDNT DO THAT SPECIFIC TEST, BUT THEY OPEN, TOO FAST FOR MY CAR'S CURRENT STAKE IT SEEMS.
I THOUGHT I HAD IT THERE, BUT MESSED WITH IT AGAIN WHEN I COULDNT DRIVE IT BACK INTO THE DRIVEWAY. SCREWED IT ALL UP.
NEXT TIME ITS WARM I THINK I NEED TO LOOK FOR OBVIOUS VACUUM LEAKS AND SET EVERYTHING I CAN TO SPEC.
ON THE TURNBUCKLES, THE FRONT ISNT TWISTING AS EASILY AS THE BACK. I WIDH I KNEW HOW TO SET A FACTORY SPEC ON THAT.
My signature:
Fonzi is offline
post #84 of 138 (permalink) Old 02-18-2015, 10:34 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Indeed, concise and simpler!
adler is offline
post #85 of 138 (permalink) Old 02-20-2015, 05:40 PM
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
Fonzi, I am counting on you to figure these carbs out so you can walk my through tuning mine.
audley115 likes this.
dgosh28 is offline
post #86 of 138 (permalink) Old 02-20-2015, 05:47 PM
dgosh28's Avatar
Quoted: 103 Post(s)
How important is it to have the electrical choke wires hooked up that plug into the front of the carbs? The carbs I bought for my car had the wires cut and I didn't know to install them, I realized it months later. I have a set I can install if it will make a big difference. The car starts, idles, and drives fine without them as far as I can tell.
dgosh28 is offline
post #87 of 138 (permalink) Old 02-20-2015, 06:52 PM
rumb's Avatar
Quoted: 463 Post(s)
? front of carb? picture maybe?
there is a switch on the front of the front carb that controls the tranny kickdown when you come to a stop.
the chokes just have one wire.
rumb is online now
post #88 of 138 (permalink) Old 02-20-2015, 09:07 PM Thread Starter
Fonzi's Avatar
Yeah. Chokes are in the rear of the carbs with wire connections on domed shaped things that you can twist if they are cleaned and bolts are loosened.
I think I recall you mentioning another wire that was related to something that stops dieseling when the car is shut off.
My signature:
Fonzi is offline
post #89 of 138 (permalink) Old 02-21-2015, 05:50 AM
rumb's Avatar
Quoted: 463 Post(s)
the fuel return valve on the front carb - brass - is what prevents dieseling and vapor lock.
rumb is online now
post #90 of 138 (permalink) Old 02-21-2015, 05:56 AM
rumb's Avatar
Quoted: 463 Post(s)
Here are some diagrams from BMW - they use the same Zenith with a few differences. Help you visualize a few things.
ID:	1334257   Click image for larger version
ID:	1334265   Click image for larger version
rumb is online now
