Need Help Fuel Issue - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-04-2014, 01:41 PM Thread Starter
Date registered: Mar 2014
Vehicle: 1970 280se
I have a fuel issue in my 1970 280 SEL. It turns on and idles fine and after you put in gear it runs for 2 - 3 minutes and dies. I have replaced the fuel pump and fuel filter 2x.
michellehmcclure is offline
post #2 of 9 (permalink) Old 03-04-2014, 02:08 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1651 Post(s)
EDIT: Oops. Sorry. I assumed the first injection system was the Bosch D-jet. Still learning.
My signature:
Click for list of my 33 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 9 (permalink) Old 03-04-2014, 02:28 PM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Is it an injected fuel system or carburated? I had a similar issue but mine has the two zenith carbs.
Luna Gaudi's 72 250 is offline
post #4 of 9 (permalink) Old 03-04-2014, 05:39 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
If 280sel, fuel injected, no carb no d jet tonic then
baybear
Baybear is offline
post #5 of 9 (permalink) Old 03-04-2014, 07:01 PM Thread Starter
Vehicle: 1970 280se
injected
post #6 of 9 (permalink) Old 03-05-2014, 01:26 AM
Fonzi's Avatar
baybear
That sure is cryptic. Edit, Ahh... Now that I see there was another injection system prior to the D-jetronic, I see this makes sense.
My signature:
Fonzi is offline
post #7 of 9 (permalink) Old 03-05-2014, 11:57 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Does it tend to die more when the fuel is below 1/4 tank or less? Does it die but you can restart almost immediately but will then die again? I've become the evangelist for telling people they should always remove, inspect and clean or replace the fuel strainer that is in the fuel tank accessible from the plug beneath. This clogs and is not part of the typical "change the filters" service. It's a fairly cheap part and common for hard to diagnose fuel issues.
There are other possibilities but this is pretty typical unless you know your fuel tank has been cleaned and recoated recently, in which case this would have been attended to.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #8 of 9 (permalink) Old 03-08-2014, 07:46 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Yeah, I'm with DirectLA on this one. That strainer cleaning can make a huge difference
Grubeguy is offline
post #9 of 9 (permalink) Old 03-09-2014, 04:48 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
before replacing anything , try figuring what is going on .in this case , get a gauge that reads up to 30 psi or so [ hardware store ], a fitting that screw into that gauge to put a piece of gas hose , connect it at the fuel line at the cold start valve [ unplug it ] with rubber hose and a clamp . fuel pressure should be about 10 psi .the car will run on a low side , like 2 or 3 . start car and let it run , and see , pressure should not move .if it slowly goes to zero , and engine quit , problem will be at tank .i would also replace the fuse for the pump .
agillot is offline
