W111 Zenith Carburetor Adjustment Help - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 02-28-2014, 09:00 AM Thread Starter
Date registered: Feb 2008
Vehicle: MB 1964, 220sb, W111 ---- MB 1997, E200, W210 ---- MB 2012 C180 W204
Hi there!
I am in need of an adjustment guide for my Zenith twin carburetor. I guess it's a 35/40 INAT model sitting on my 1964, 220sb. Any help or link finding an adjustment manual is highly appreciated.
Thanks!
Abye is offline
post #2 of 14 (permalink) Old 02-28-2014, 09:51 AM
Date registered: Oct 2008
Vehicle: 1959 190, 1961 190SL, 1967 250SE 4Spd, 1968 220D 4spd
Quoted: 5 Post(s)
A basic thing to check is that the two carbs draw air in equal amounts. A synchrometer will help with this, but you will likely need some kind of flange adapter to fit correctly. You can adjust the air volume via the idle control screw on each carburetor. Make sure to disconnect the linkage between the two when doing this.
If the carbs are drawing air equally, but idle is unstable, there's likely an air leak somewhere, which is compromising the air/fuel mixture. This can have several causes, but a carb rebuild could be required. Not too difficult with those carburetors.
elduderino is offline
post #3 of 14 (permalink) Old 02-28-2014, 10:38 AM
Date registered: Dec 2006
jmela is offline
post #4 of 14 (permalink) Old 02-28-2014, 07:58 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
In addition to the manual you will require a carb synchronizer. (jcwhitney etc carry them)
Once you have set them up and balanced they work very well in these models.
I have found them to be perfect for these models ,occasionally they will get warped surfaces due to a overheated engine.
Fitted to period BMW's too and kits available from them.
adler is offline
post #5 of 14 (permalink) Old 03-01-2014, 04:59 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
It's not obvious in the adjustment instructions, but you balance using #12 idle speed adjustment - on the vertical linkage, and adjust mixture with #15 idle mixture screw on the side of the base, per the instructions.
rumb is offline
post #6 of 14 (permalink) Old 03-01-2014, 08:21 AM Thread Starter
Thanks for the reply! Good start...
However, I was wondering the actual model of the Zenith. Is this a 35/40 ? or...
The Chassis number is 111012-10-128179 and Engine number 180941-10-115763
Thanks again!
Abye is offline
post #7 of 14 (permalink) Old 03-01-2014, 06:28 PM
Quoted: 59 Post(s)
35/40 INAT.
adler is offline
post #8 of 14 (permalink) Old 03-02-2014, 09:18 AM
rumb's Avatar
Quoted: 480 Post(s)
FWIW, It's worth checking all the jet sizes if you have or think you have a carb that has been replaced. Zenith were used on many MB and BMW models and all have different jet specs.
rumb is offline
post #9 of 14 (permalink) Old 03-02-2014, 04:33 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1717 Post(s)
I have a real crap box 1971 250 m130 that is just got running today, and assume the carb will require a rebuild. I'm in the Philadelphia area and will probably be following your path. Maybe some tool sharing? If I get ahead of you I will be sure to let you know. (Some zenith manuals seem to be in one of the sticky threads.)
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #10 of 14 (permalink) Old 03-04-2014, 08:16 AM Thread Starter
Hi Fonzi,
I noticed the manual found on this page is quite interesting and a step by step guide will ensure a good result at the end.
Zenith Carb Manual TOC
I got a rebuild kit (original Mercedes part A 000 586 01 07) from a local Benz dealer. You should be able to get one on ebay or so...
Will keep you inform...
Cheers!
Abye is offline
