Idle air m116 3.5, how's it work?? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 01-25-2014, 03:39 PM Thread Starter
Pizing82's Avatar
Date registered: Jun 2013
Hi fellow enthusiasts, I'm wanting to know how an m116 controls idle speed.
The throttle body on my car has I port above the butterfly and 2 small drillings below. The drilling at the rear is being used for vac advance for the ignition system and the one in front is blocked off with a plug.
The main port runs to a valve which looks thermostatically controlled. The valve is always open and does not close, possibly u/s.
There is another valve with a mechanical screw. I think like a power valve. Fully closed this valve allows air to pass also. I would think you could screw this closed and stall the engine but it's not the case, anyone know about these components??
Pizing82 is offline
post #2 of 9 (permalink) Old 01-26-2014, 10:43 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
The big one with the screw is your idle adjust. The other one acts as an air bypass valve, though the nomenclature escapes me. If you go to the online resources portion of the forum, there are articles uploaded that will give you an in depth overview of the engine.
Aside from obvious displacement differences between the 4.5 and 3.5, both are nearly the same, and the fuel, gas and air management systems identical.
Grubeguy is offline
post #3 of 9 (permalink) Old 01-26-2014, 06:05 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
cold start air is thermostatically adjusted as the engine warms up the thermostat closes off the extra air and idle speed returns to normal.The idle screw is used to fine adjust the correct idle rpms ,likely 750.
adler is offline
post #4 of 9 (permalink) Old 01-26-2014, 06:09 PM Thread Starter
Pizing82's Avatar
So if the thermostatically controlled valve is not working, I will likely have a fast idle hard to slow down? The idle races a bit but it does slow down as the car warms up
Pizing82 is offline
post #5 of 9 (permalink) Old 01-26-2014, 08:58 PM
Quoted: 59 Post(s)
[QUOTE=Pizing82;7546305]So if the thermostatically controlled valve is not working, I will likely have a fast idle hard to slow down? The idle races a bit but it does slow down as the car warms up
I assume you have checked for leaky air pipes, and quite a few on the top , likely the thermostat is faulty or binding due to scaling .
adler is offline
post #6 of 9 (permalink) Old 01-27-2014, 08:34 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the air slide valve goes bad with time , it does no longer shut off on a hot engine , so you end up with a high idle .
agillot is offline
post #7 of 9 (permalink) Old 01-27-2014, 05:15 PM
Grubeguy's Avatar
Quoted: 104 Post(s)
The engine rpm may hunt up and down as well, due to a bad valve.
Before replacing that thing, check/replace vacuum lines and their connections. This fuel delivery system relied on vacuum to feed input to the engine control unit. When I bought my 108, it ran like crap. Replacing the vacuum lines made a big difference (replacing the condenser with a pertronix unit was another big factor).
Grubeguy is offline
post #8 of 9 (permalink) Old 02-08-2014, 05:29 AM Thread Starter
Pizing82's Avatar
I boiled some water and popped the valve in. I saw the plunger move up but when I blew through the valve it was still flowing quite easy. Any ideas who sells a replacement valve at a reasonable price??
Pizing82 is offline
post #9 of 9 (permalink) Old 02-08-2014, 08:29 AM
Grubeguy's Avatar
Quoted: 104 Post(s)
I bought mine at Napa Autoparts. I'd suggest calling around to see who might have them stocked.
Grubeguy is offline
