Break in oil - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-25-2014, 01:04 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Break in oil
Talking to few people it was recommended that I use "break in" oil the first time I start the engine and not regular oil.
Wondering if someone has any thoughts on this and if I should use this high zinc oil?
The manual doesn't mention anything and the engine rebuild shop didn't have any recommendations
Thank you
kavadarci is offline
post #2 of 5 (permalink) Old 01-26-2014, 12:42 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 463 Post(s)
YES, it contains extra zinc and other good stuff. You can buy a can of additive like
Lucas ENGINE BREAK-IN OIL ADDITIVE - TB ZINC PLUS
After that Rotella would be good for the rest of the time as it has the extra zinc also.
the manual doesnt say anything because back then all oils had the additives in them.
rumb is offline
post #3 of 5 (permalink) Old 01-26-2014, 01:46 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Thank you
post #4 of 5 (permalink) Old 01-27-2014, 09:31 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
it is not a issue on this type of engine , a brand name oil is fine , 10/40
agillot is offline
post #5 of 5 (permalink) Old 01-27-2014, 10:58 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Regular oil it is then
I will also be using assembly lube for that extra lubrication required during the first few cranks
