1997 S500 Noisy steering pump - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-24-2014, 03:20 PM Thread Starter
Date registered: Jan 2008
After these cold nights my steering pump is making an awfully loud noise, car running, I turned steering wheel a few time from end to end a few times with the reservoir opened, no change.
Would a system flush help? if not, roughly, what would be the cost of rebuilding the pump at an indy?
angmed is offline
post #2 of 4 (permalink) Old 01-26-2014, 11:54 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
try the W140 forum, complete your profile with location, and buy a new power steering pump and tank, cause there is a filter in there you cant replace. (have you checked to see if the fluid level is low?)
rumb is offline
post #3 of 4 (permalink) Old 01-27-2014, 08:29 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
replace the reservoir only .has a filter inside .
agillot is offline
post #4 of 4 (permalink) Old 01-28-2014, 02:23 PM
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
A frugal fix would be to take the reservoir off and flush it with gasoline, that will clear the filter which is a thin mesh. New fluid and it should be fine.
unimoged is offline
