garage find - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 01-23-2014, 11:21 PM Thread Starter
Date registered: Jan 2014
Vehicle: 1975 280s
garage find
I recently bought a 1975 280s that has always been garaged. Unrestored in near mint condition. It did need a front end alignment and new tires. I have rediscovered the pleasure of driving! I need help with an electrical issue with the power windows. They only work periodically and I have checked the fuses and all 4 switches. All ok. It's probably a bad connection or maybe a master relay. Any ideas?
ID:	749033   Click image for larger version
mercymercy is offline
post #2 of 15 (permalink) Old 01-24-2014, 04:31 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
I'm betting corroded contacts in the switches. I'm not familiar with the design of the older models but you may can take the switches apart and clean the contacts with sandpaper.
Beautiful car. How many miles on it?
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 15 (permalink) Old 01-24-2014, 09:39 AM
KarlC's Avatar
Date registered: Jan 2004
Vehicle: 1994 E500
Also check to see if all the fuses are orgional if they are change them out with no fuses. Older fuses can have corrosion that can cause this problem
Nice find load up more photos
KarlC is offline
post #4 of 15 (permalink) Old 01-24-2014, 10:50 AM
Date registered: Jul 2008
Quoted: 334 Post(s)
Remove and replace all the fuses with copper/brass cermaic ones....they may look good but can have bad ends...
As was said the switches probably also need cleaning...
I would also plan on removing the regulators from the doors and cleaning them...
cooljjay is offline
post #5 of 15 (permalink) Old 01-24-2014, 11:42 AM Thread Starter
Vehicle: 1975 280s
more of the 75' 280s
Thanks for all the quick response to the power window problem. I guess I didn't realize that all four switches could go bad at the same time but I guess a car this old that anything is possible. I will replace the fuses too. Here's a couple more pic.
Thanks again guys
ID:	749881   Click image for larger version
post #6 of 15 (permalink) Old 01-24-2014, 12:17 PM
Peoria Benz's Avatar
Date registered: Jul 2006
Sweet ride! I would start with the fuses. Also, it is easy to prey up the window switches and check for current in and out of the switches. Happy motoring!
Peoria Benz is offline
post #7 of 15 (permalink) Old 01-24-2014, 02:04 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
To further trouble shoot, does it only affect the switches in the console or is it the rear door switches that don't work consistently too? If the console switches do not work and the rear ones do, it is likely the switches in the console. If no switches work, it is likely the fuses. If the console works but not the rear, it is likely the child lock switch in the console.
As said above, the switches are easy to remove, take apart, clean and put back together.
TZ_280SEL is offline
post #8 of 15 (permalink) Old 01-24-2014, 08:07 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 115 Post(s)
I vote for the switches. In the center console.
Scoot is offline
post #9 of 15 (permalink) Old 01-24-2014, 08:20 PM Thread Starter
Vehicle: 1975 280s
Scoot,
The more I read the more your suggestion is right.
Thanks
post #10 of 15 (permalink) Old 01-24-2014, 08:41 PM
Scoot's Avatar
Quoted: 115 Post(s)
You can get them from autohausaz.com fairly affordably compared to buying them from MB.
Scoot is offline
