Brake lights flash briefly but won't stay on - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-18-2014, 07:20 PM Thread Starter
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Brake lights flash briefly but won't stay on (Resolved)
My brake lights illuminate briefly but won't stay on for more than a few seconds while pressing the brake pedal, almost as if they are overheating and a fuse is kicking them off but they will come back on again briefly if I let off and press again? Any suggestions? I do not believe it is a ground because I am adamant about keeping them in good shape and no other symptoms. Could the brake pedal switch cause this or...?
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #2 of 6 (permalink) Old 01-18-2014, 07:55 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Most likely the switch . If you remove the connector at the switch and connect the pins with a wire it will confirm operation of lights .
A shot of contact cleaner will likely get the switch and pins operational .
adler is offline
post #3 of 6 (permalink) Old 01-19-2014, 12:28 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Thank you. Do I need to remove the pedal assembly or anything in-depth to reach the switch or is it readily accessible to remove fully to clean? I won't be able to have a look at my car until later this week.
-Marrs
DirectLA is offline
post #4 of 6 (permalink) Old 01-19-2014, 05:58 PM
Quoted: 59 Post(s)
No. Removal of pedal required.simple plug removal.
adler is offline
post #5 of 6 (permalink) Old 01-21-2014, 03:15 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
After using Adler's method (thanks!) to test the circuit I realized the pedal actuated switch was fine, so I then found that the pressure switch mounted to the master cylinder wasn't working properly. I was able to find a suitable replacement and with some minor work on the connectors, the brake lights again function as they should. I will be putting together a DIY for this repair with pics in the next couple of days and will add the link to this thread.
It was a very simple repair and one I found fairly enjoyable being rather straightforward. Those are rare so I will take them when I can.
-Marrs
DirectLA is offline
post #6 of 6 (permalink) Old 01-30-2014, 01:18 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
As promised, you can find the link to my brake light tutorial on The Coupe Group DIY page here. It will take you to my art site where the articles are hosted.
Brake Light Pressure Switch DIY
-Marrs
DirectLA is offline
