Gasket - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-18-2014, 09:07 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Gasket
Hi
When I use gaskets such as head gasket, oil pan gasket and similar should I use silicon with the gaskets or just the gasket itself?
Thank you
kavadarci is offline
post #2 of 5 (permalink) Old 01-18-2014, 10:18 AM
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 176 Post(s)
MB gaskets
and machined mating surfaces are excellent. I use a thin coat of grease on the gaskets to hold them in place while mating the parts. Nothing else.
rocky raccoon is offline
post #3 of 5 (permalink) Old 01-18-2014, 01:34 PM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
A coating of oil or light grease is fine as rocky mentioned. When replacing your head and after the gasket is on ,place two small clean pieces of 3/8 ply or wood on top of the gasket before placing the head for safety. Just a suggestion .Good luck with everything. You are doing great.
Harald
Over 75 is offline
post #4 of 5 (permalink) Old 01-18-2014, 04:03 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Thank you guys.
post #5 of 5 (permalink) Old 01-19-2014, 06:48 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
head gasket DRY , no glue there . the aluminum pan to block , use permatex number 2 , others use aviation FORM A GASKET sealant liquid [ napa 765 1210 ] or same called high tack .
agillot is offline
