Water pump gasket - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 01-19-2014, 03:21 PM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Kav, this is from agillot just a few posts up.
Originally Posted by agillot View Post
NO , NO , never seen that , just gasket with some light sealer , a brush on type , like permatex aviation sealant liquid [ napa 765 1210 ].the pump should be clocked one way , with the drain hole at bottom and the cut at flange around 10 o clock .you should replace the pump .
Luna Gaudi's 72 250 is offline
post #12 of 13 (permalink) Old 01-19-2014, 03:29 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
just the gasket
rumb is offline
post #13 of 13 (permalink) Old 01-19-2014, 10:39 PM
Date registered: Apr 2013
Vehicle: '95 E320 Wagon,'71 250C(For Sale!)
Quoted: 24 Post(s)
Looks like mine is rotated too far to the left. Havnt had any
issues with it this way. I will leave it until its time to replace
the pump with a new one.
If Agillot is correct, Luna's water pump is in the correct position as the cut out is at 10am. I pulled out my Graf replacement pump and there are holes 180 degrees opposite of each other. One hole has no bump out. As shoen in Luna's photo, the bump out hole is facing downward.
Who is right?
FYI, Graf says to not put any gasket dressing on the paper gasket. I will assume the printed side of the gasket goes to the engine block surface.
hages is offline
