W114 Wood Refinishing Attempt - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 01-17-2014, 03:09 PM Thread Starter
Date registered: Apr 2013
Vehicle: '95 E320 Wagon,'71 250C(For Sale!)
Quoted: 24 Post(s)
I finally got a chance to redo at least the glove box door wood and had trouble stripping the shellac or whatever is applied over the wood veneer.
I read on a R107 forum a person using a heat gun and a putty knife to strip away the clear coat. It certainly softened up the old coating but it is not really effective to completely strip off the coating. Basically I smeared it off and left a film on the veneer.
I then tried lacquer thinner with little effect despite leaving it on for 10 minutes, then tried denatured alcohol that worked better with hard persistent rubbing with a cloth. Fine steel wool did not assist in the removal.
Then a few coats of satin clear coat with sanding in between, and the results was reasonable.
Is there any other suggestions to make the clear coat removal easier? I would not want to use the heat gun as I am hoping to do the remaining wood in place on the dash.
Before/After Pics:
hages is offline
post #2 of 14 (permalink) Old 01-17-2014, 03:58 PM
KarlC's Avatar
Date registered: Jan 2004
Vehicle: 1994 E500
Good start, the before and after shots make it look great.
1993 500E 040 / 271 - Porsche Type 2758 ~~~~ 1971 250C Ivory / Cognac Leather
1994 E500 - Sold
2003 CL600 - Sold
1994 E500 - Sold
1995 E320 Cab - Sold
1988 BMW M6 - Sold
1994 E320 Cab - Sold
KarlC is offline
post #3 of 14 (permalink) Old 01-17-2014, 04:06 PM Thread Starter
Quoted: 24 Post(s)
Thanks. Weird how the shellac looks like the car was baked in the Texas desert!
Keeping an eye on your Stroke 8 project updates!
hages is offline
post #4 of 14 (permalink) Old 01-17-2014, 05:41 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
If indeed it is shellac, alcohol is the solvent. Shellac once was a popular finish for furniture because it dried so fast. It does alligator as in your first photo and also is not resistant to water.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #5 of 14 (permalink) Old 01-18-2014, 11:36 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
MB used a catylised finish, tougher than nails. use a good paint stripper and then use only steel wool to remove. may take several coats. the veneer is as thin as paper so dont sand or scrape.
rumb is online now
post #6 of 14 (permalink) Old 01-18-2014, 01:09 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I think it looks great so far but agree with others that sanding in not recommended, it will go bare around the edges quickly. Heat, likewise, could cause it to separate at the glue substrate level.
When I did mine, looked just like your before pic with a leathery cracking, I used a Super Strength Paint Stripper Gel, I forget the brand but it was a well known one right off the shelf at the hardware store. I liberally covered with the gel using gloves and a paint brush, keep it even and thick, it only works when wet. Let it sit for half an hour or until dry then scrape ***with a plastic scraper, not metal to avoid gouges*** and then once most is off go at it with #0000 grade steel wool, also from the hardware store.
If the first coat of stripper (that reminds me, I need to stop buying coats for strippers) doesn't get all the veneer off, do another coat. This basically does the work for you and you will never prep wood any other way after doing this. Good luck and show us your results, again, looks great so far!
The Coupe Group on Facebook
DirectLA is offline
post #7 of 14 (permalink) Old 01-18-2014, 02:09 PM Thread Starter
Quoted: 24 Post(s)
Yes, I agree also that sanding is a no no and with a heat gun there is the risk of burning the veneer. I also tried a super stripper gel but did not leave it on for very long. Will give it at least 30 mins of working time next go around.
hages is offline
post #8 of 14 (permalink) Old 01-19-2014, 05:48 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I redid the wood in my 108 and used stripper also. There was no damage to the wood whatsoever, and I used a plastic putty knife to get the stuff off. It'll take a while. I ended up using marine grade polyurethane to finish the stuff, which has withstood heat, cold, etc. I took all the wood off though - it's not something to do while installed.
Grubeguy is offline
post #9 of 14 (permalink) Old 01-19-2014, 05:57 PM
Date registered: Jul 2008
Quoted: 320 Post(s)
Theres a thread around here some where showing how simple it is to get this stuff off..
here we are
Got me some cheap dash wood for my W123 300D - PeachParts Mercedes ShopForum
Your doing an good job....but you need to fill that grain more....it looks like you just piled it....you really have to pile on the lacquer to fill the grain then sand it way down and repeat till its filled.
cooljjay is offline
post #10 of 14 (permalink) Old 01-19-2014, 06:20 PM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
If you are into it, you can do what I did and vinyl wrap the dash wood
I did black carbon fiber
kavadarci is offline
