1967 230S Motor versus 1968 250SE Motor - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 01-19-2014, 07:08 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
110 and 111 had single pipes and work well
. If the distributer centrifugal weights are jammed due to lack of lubrication OR. timing chain stretch the engine will be sluggish.
adler is offline
post #12 of 17 (permalink) Old 01-22-2014, 11:38 PM
Date registered: Jan 2009
Vehicle: anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
Quoted: 11 Post(s)
230 S (??)
Are you talking about the car in the photo on the very first post ?
I have to disappoint you, but that is a 230 (a?, plain 230)
And if in fact that is the subject car :
I cannot tell from the small photo, what motor you have in there.
And most of all what carburetors.
If it has the small Solex carbs, you could upgrade to the (real) 230S cars' :
the Zenith INAT 35/40, that are better carbs.
Alex
6punkt3 is offline
post #13 of 17 (permalink) Old 01-23-2014, 12:43 AM
Jackpody's Avatar
Date registered: Oct 2012
Vehicle: Mercedes Benz W108 - 280 SE (1970) / Mercedes-Benz W123 200T (1983)
Quoted: 13 Post(s)
Aren't the Zenith carbs a bit of a PITA though? I remember hearing people have lots of trouble with the Zenith carburators for the W108 - not sure if it's the same for the W111.
Jackpody is offline
post #14 of 17 (permalink) Old 01-23-2014, 01:59 AM
Dr. Sternschnuppe's Avatar
Date registered: Dec 2011
Vehicle: 600 (3.200 mm)
Quoted: 141 Post(s)
Arrow
Alex
I agree, on the photo in the first post is the Type 110, not 111.
The 230 (110.011) and 230 S (111.010) both have M180 engine.
The 230 has engine with two Solex 38 PDSI-2 only up to 06.1966. And from 07.1966 the 230 have identical to 230 S engine with two Zenith 35/40 INAT.
The subject car is 1967 model.
Salut!
Mercedes-Benz. Ihr guter Stern auf allen Strassen.
Dr. Sternschnuppe is offline
post #15 of 17 (permalink) Old 01-29-2014, 07:25 PM Thread Starter
Date registered: Mar 2013
Vehicle: 1967 Fintail 230S
Hi all, thanks for all the input. The car is indeed a 1967 w110, 230, no 's'. It has a 2.3L straight six engine, with two Weber downdraught carbs. No p/s, no A/C. The potential donor 250SE has power steering and air conditioning. I am not sure if these engine components from the 250 would bolt on to 230 engine. The distributor on the 230 is on the side of the engine, while the dizzy on the 250 looks like it's driven from the timing cover. It seems like this change was made to accommodate the FI distributor that's on the side of the 250 motor.
The 230 is a manual gearbox which I would like to retain, and the 250 is automatic tranny (yuck).
The 250 is not in a good location for parts stripping, the owner can't find the title, and my wife would kill me if I brought another old rusted out car home. It really looks terrible. Would be nice if I could upgrade my car with those parts though.
Coolvibes is offline
post #16 of 17 (permalink) Old 01-29-2014, 07:32 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
I wasn't aware of a weber upgrade for that intake manifold. I would think twice before ditching the weber carbs and intake in favor of a M129 / M130 engine. Could you post a picture of your carbs and intake please? Want to sell your carbs and intake?
Scoot is offline
post #17 of 17 (permalink) Old 01-30-2014, 01:35 PM
Scoot's Avatar
Quoted: 121 Post(s)
On a related note, a 1967 250 M129 motor _might_ have an oil cooler under the left motor support. a 1968 280 M130 motor _probably_ has an oil cooler with the radiator. A W110/W111 might not have any oil cooler. So if you switch engines you want to get an oil cooler setup that goes under the left engine mount with the engine because it isn't going to fit anywhere near the radiator to the best of my knowledge... I don't think power steering pump addition will be a problem although you will probably need a bracket that you don't have. Auto trans will probably require a trans cooler that you also don't have.
GL with project, I would like to hear more about Webers on an M180...
Scoot is offline
