Again engine assembly question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-01-2014, 05:51 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Shop called me and the engine work is done
I have all the parts to start putting it together but the weather is crazy cold and my garage is not heated.
What I need to know is this:
Is it ok to put the engine together but not start till spring or should I just keep the parts indoor and start putting it together in spring?
Thank you.
Sent from Free App
kavadarci is offline
post #2 of 3 (permalink) Old 01-01-2014, 06:05 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
do it now , it is well oiled , i have kept some engine 1 year , no problem . plus if you have a tech problem , this will give you some extra time .
agillot is offline
post #3 of 3 (permalink) Old 01-01-2014, 06:45 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
1) Measure up your engine stand and see if you can wheel it into the house through the doorways
2) If yes, go and buy your partner a diamond ring or some other present
3) With the accrued brownie points, select a room in the warm house and assemble engine there. Then wheel the completed engine to the garage when spring comes.
Good luck and let us know if this strategy works - if we don't hear from you in a week, we know that the reaction was not good!
Cheers, Drew
drew56cus is offline
