W108 / W109 Wheel Picture Thread - Page 2 - Mercedes-Benz Forum
post #11 of 44 (permalink) Old 01-09-2014, 10:49 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 136 Post(s)
Originally Posted by KarlC View Post
I really like the general look of the OEM Classic Vintage wheels, I just don't like the size or the weight of them, so here is a little wheel project that I am working on for my 71 250C.....
It's fine if you like the mod. I agree about the weight. On my 71 250C I went for the 14" aluminum wheels that weigh 11 pounds. To each their own, mine ended up looking stock and weighing less which I very much liked...
I am unclear on something - do tires for bigger rims weigh more? How much more?
cheers
Scott
Scoot is offline
post #12 of 44 (permalink) Old 01-09-2014, 10:59 AM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
Interesting and good idea Karl. For mounting caps you may try I think clips from older VW wheels (5 lug I believe), think they had some with riveted clips.
Or even have some little nubs tig welded on the rim. What color will the spokes be painted. Later.
50$84sd is offline
post #13 of 44 (permalink) Old 01-09-2014, 11:14 AM
Scoot's Avatar
Quoted: 136 Post(s)
FWIW I believe that Mercedes sells the studs that are used on the early dog dish hubcaps/wheels and they can be mounted by drilling the wheel and possibly tapping the hole. Check on the sl113.org of 190sl forum - there is a write-up on one of those for adding dog dish hubcaps to aluminum wheels.
Scoot is offline
post #14 of 44 (permalink) Old 01-09-2014, 11:16 AM
Scoot's Avatar
Quoted: 136 Post(s)
AL 14" Rims - "Heckflosse" hubcap mounts [Archive] - International 190SL Group Forums
Scoot is offline
post #15 of 44 (permalink) Old 01-09-2014, 12:32 PM
KarlC's Avatar
Date registered: Jan 2004
Vehicle: 1994 E500
cheers
Scott
Scott, you are of course right this would be only for guys that like to mods their cars. I like the OEM + look, like a special car that could have come from the factory. So I will lower my car a bit and up size the wheels n tires.
If I have my numbers right weights would be like this....
Stock - 14x5.5 steel wheel 23 lbs 195/70/14 tires on my car 18 lbs - Total 41lbs
Stock + - 14x5.5 alloy wheel 11 lbs 195/70/14 tires 18 lbs - Total 29lbs
Stock ++ - 16x7 CLK alloy wheel 13 lbs 205/55/16 tires 20 lbs - Total - 32lbs
I'm not 100% sure what tire size I will use yet, maybe 205/55/16 or 215/50/16 or 225/50/16 the bigger the tire the more the wight and tire brands can very a few lbs even within the same size.
1993 500E 040 / 271 - Porsche Type 2758 ~~~~ 1971 250C Ivory / Cognac Leather
1994 E500 - Sold
2003 CL600 - Sold
1994 E500 - Sold
1995 E320 Cab - Sold
1988 BMW M6 - Sold
1994 E320 Cab - Sold
KarlC is offline
post #16 of 44 (permalink) Old 01-09-2014, 12:43 PM
KarlC's Avatar
Vehicle: 1994 E500
The wheel center spokes will be painted body color like the hubcap I did, this should give them the most OEM look.
1994 E500 - Sold
2003 CL600 - Sold
1994 E500 - Sold
1988 BMW M6 - Sold
KarlC is offline
post #17 of 44 (permalink) Old 01-09-2014, 01:11 PM
Scoot's Avatar
Quoted: 136 Post(s)
Isn't the offset going to be wrong for the later CLK wheel? (I don't know, it's just a question worth investigating...) Also the combination of lowering car and increasing the wheel width makes me wonder about rubbing...
Scoot is offline
post #18 of 44 (permalink) Old 01-09-2014, 01:35 PM
KarlC's Avatar
Vehicle: 1994 E500
I've read a few things, can you confirm what the stock 14x5.5 wheel off set is ?
1994 E500 - Sold
2003 CL600 - Sold
1994 E500 - Sold
1988 BMW M6 - Sold
KarlC is offline
post #19 of 44 (permalink) Old 01-09-2014, 09:35 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Iím using these on my 111 coupe. 15x7 in front and 16x8 rear. The look very classy, are original Mercedes and allow more modern size tires.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #20 of 44 (permalink) Old 01-09-2014, 10:06 PM Thread Starter
MCMLXIX's Avatar
Date registered: Dec 2013
Vehicle: 2006 S65 AMG V12 Biturbo
Quoted: 87 Post(s)
Tony -
Do you know the ET for each pair?
What size tires are you running on each pair?
Do you know what model these originally came on?
.. oh, can we see pics of your car with these on there?
Thanks
Rich
Rich
2006 S65 AMG 1 of 427 in North America {For Sale}
1986 560SEL {FOR SALE}
MCMLXIX is offline
