W110 column gear shift trouble... - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 12-23-2013, 12:54 AM Thread Starter
Date registered: Dec 2013
Vehicle: W110 1962 fin tail.
Hi,is there anyone out there that can HELP???
I have recently purchased a beautiful 1962 w110 fin tail on the net,on arrival the courier advised me that the vehicle would not engage into reverse.
After contacting the previous owner,he said he had no issues with the vehicle???? On inspection I can see there has been some bush mechanics done on the linkage,ie wire and rubber bands wound round one of the linkage arms. The vehicle engages all 4 forward gears problem free.
Is there a new kit that I can purchase to replace what's wound round what I've got?
Look forward to you guys wisdom helping me out as I'm at a loss!!!!
Murray.
Murray Gamba is offline
post #2 of 11 (permalink) Old 12-23-2013, 09:15 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
Pics are the only way to figure this one out......
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #3 of 11 (permalink) Old 12-24-2013, 11:09 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
sign up for EPC-net Online EPC online. It will be your best friend to figure out parts. it is free, but if you have tech problem installing just call them and they will fix. there has been some issues with that.
probably just a $2 bushing needs replaced.
rumb is offline
post #4 of 11 (permalink) Old 12-24-2013, 11:59 AM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Yes, either the owner or the transport folks wired it up when a bushing broke. Depending upon where this wired bit is it could either be the ball end of the rod which you can probably snap back in place long enough to put it in reverse, or the rubber bit on top of the transmission but you probably can't see that, or the plastic bushings in the shifter column. Those bushings are all very cheap but you may not have ready availability. Your dealer should have them for very little money, maybe the cheapest thing you will ever buy for your car.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #5 of 11 (permalink) Old 12-25-2013, 04:52 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 93 Post(s)
On Monday I paid $2.55 each for two.
ejboyd5 is offline
post #6 of 11 (permalink) Old 12-25-2013, 11:36 AM Thread Starter
Hi,could you please tell me where you purchased these parts?
Murray.
post #7 of 11 (permalink) Old 12-26-2013, 05:03 AM
ejboyd5's Avatar
Quoted: 93 Post(s)
Mercedes-Benz of Southampton (New York). Probably a bit far for you, but parts should be at every M-B parts room as they are a common wear item used on many M-B models.
ejboyd5 is offline
post #8 of 11 (permalink) Old 12-26-2013, 06:42 AM
Date registered: Jan 2009
Vehicle: 99 ML 430; 61 220Sb
what are the exact part numbers for those bushings, rubber bit and the nylon part?
BlinduL is offline
post #9 of 11 (permalink) Old 12-26-2013, 06:06 PM Thread Starter
Part nr
Hi to all,is the part nr 000 991 09 22 ? Does this part have to be replaced or is there a nylon insert that is simlpy pushed into the ball socket?
I pulled the whole mechanism apart yesterday,the ball socket for all the forward gears has heaps of slop in it but still engages all 4 gears. The ball socket for reverse also has heaps of slop but it will not engage into reverse without help from a third party.
If there is a nylon bush that simply is pressed into the ball socket,does anyone out there know the part nr?
Look forward to hearing from you. Murray.
post #10 of 11 (permalink) Old 12-27-2013, 05:57 PM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
For the W110, the part number for the rod eye that screws onto the shift rod and snaps over the shifter ball at the base of the steering column is 000 991 38 22. It includes the metal end with the nylon inside, and both rods use the same one. They were about $10 each when I bought them a few months ago. They are a common failure point when the plastic gets old. Mine broke right in the middle of an intersection going up a hill. Quick fixed with a couple wire ties.
The bushing for the transmission end of the rod is 000 992 01 10.
KCM is offline
