Interesting Surprise - M129 Engine In My 220SE - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-17-2013, 01:28 PM Thread Starter
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
I've had this car for over 20yrs. and always thought it had a M127 2.2 engine but just found out that it's a M129 2.5 from a 250SE/SL.
When I first got it way back, it needed head work and gasket so had that taken care of and have been driving it on and off for years.
I felt like getting it on the road again lately so did all the maint. stuff and got it running, but noticed a couple oil leaks.
One leak was on top of valve cover at the bolts another was by the side of engine by distributor, doing some research yesterday I found that this leak on the side was at the tach drive which 220 sedans don't have.
So today I checked the block and it's got a M129 block so that was strange. I was always curious why there was a 230/250 dipstick in there too, now I know why.
So I've got a 127 head, M129 block, 127 distributor and two piston fuel injector pump. (head #1270161601, block #1290110001, distri. #VJUR6BR61T)
Well fortunately just about all parts and tuning are the same for both.
Interested mix of parts that seem to work fine. Now got to find a way to plug the tach drive. Later.
50$84sd is offline
post #2 of 4 (permalink) Old 12-17-2013, 05:15 PM
Date registered: Oct 2008
Vehicle: 1959 190, 1961 190SL, 1967 250SE 4Spd, 1968 220D 4spd
Quoted: 5 Post(s)
hmm, interesting. Doesn't the M129 block use the 3 piston injector pump? And the M129 is the best in my opinion...more power than 220, more bearings, and no overheating/AC issues of the M130.
elduderino is offline
post #3 of 4 (permalink) Old 12-17-2013, 07:01 PM Thread Starter
50$84sd's Avatar
Exclamation
Well I actually think the m129 engine had the six piston pump. Later.
50$84sd is offline
post #4 of 4 (permalink) Old 12-18-2013, 09:47 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
M129 and M130 both have 6 piston injector pumps. Put your VIN into EPC and see what engine it thinks you should have, or look on the datacard for the engine number...
Scoot is offline
