1972 W114 250C - Alternator- power issues - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-17-2013, 08:04 AM Thread Starter
Date registered: Aug 2013
Vehicle: 1972 250c, 1958 chevy biscayne, 1985 bmw 635
Hey guys, Haven't posted anything in a little while but wanted to see if any of you have come up with a solution for the problem I'm having.
I added a Sound system to the car and since then, the alternator just can't seem to keep up with the accessories. I continually have to jump the car with my battery jumper. I know the stock alternator is 35 amp… I don't know whether mine is bad and a replacement could keep up or if somehow I can upgrade to a larger amperage so when I add AC and possibly an air ride system I won't have to worry.. .
Any suggestion? Thanks!
al3xmac is offline
post #2 of 6 (permalink) Old 12-17-2013, 03:46 PM
Date registered: Jan 2007
Quoted: 82 Post(s)
Sounds like an alternator, battery, or voltage regulator problem. Have you checked the battery voltage with the engine running?
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 6 (permalink) Old 12-17-2013, 04:46 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
35 amps doesn't do a decent sound system a lot of justice. Somewhere in the owner's manual, it'll tell you how much amperage the new system draws. Take that, add in extra for an amp if you have one, headlights, etc, and you'll probably hit or exceed the rated output for your alternator.
You'd have to probably rig up a specialty bracket, but you could easily upgrade to something with more juice - a modern benz unit or something less expensive from a Chevy or Ford.
If you want to test your alternator, take it to an autoparts store - the ones here all test the things for free. I'm about 99% certain yours has an internal regulator. You can also have the battery tested at the same time.
Grubeguy is offline
post #4 of 6 (permalink) Old 12-18-2013, 05:50 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Most likely the alternator requires service .Worn carbon bushes or a bad diode will drastically cut output yet show good until its load tested.
adler is offline
post #5 of 6 (permalink) Old 12-18-2013, 09:30 PM
Date registered: Feb 2011
Vehicle: 1973 220D
1972 w114 would have a Bosh alternator and an external voltage regulator. 35A is might be OK even if your sound system draws more than that occasionally but possibly not enough. It could be that your alternator was weak and the new sound system is too much for it.
The test is simple - measure the voltage at the battery with the engine running and sound system off and with it on. If the voltage drops below 13 with the sound system on (headlights and fan too) then you need a new / rebuild and possibly bigger alternator.
See this thread - there was another I can't find right now as I recall the fellow found a Ford alternator that did fit. To go from 35A to 55A would probably work with existing wiring although you do run the risk of heating and melting the insulation in your wiring harness. I have seen this happen and it is not pretty.
frankflynn is offline
post #6 of 6 (permalink) Old 01-02-2014, 07:54 PM Thread Starter
Thanks guys, Ill update everyone once I figure this out. Im having a few problems with the car that need to be taken care of. Having new Carbs installed now, alternator and AC are next...
al3xmac is offline
