Would These Bosch Plugs Work In My 220SE - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-12-2013, 07:33 PM Thread Starter
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
I've got a set of these WR9LS plugs that I think I bought many years ago and had to be for my '65 220SE.
Just got it running again today after many many months of neglect. Needed new points and condenser for now.
Can't find any info so what about it. Thx. Later.
50$84sd is offline
post #2 of 7 (permalink) Old 12-12-2013, 08:15 PM
Date registered: Jan 2009
Vehicle: anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
Quoted: 11 Post(s)
not sure
Hi Later,
old Bosch designation.
nowadays they only give you parts numbers, so you can't figure out cross references.....
the WR9LS stands for resistor (old radios needed that so it wouldn't interfere)
the WR9LS stands for heat rating or spark strength (9 is kind of hot and for city driving only, or if your motor fouls them up with oil or too much gas, I remember buying 8 or even sevens for my old finnies, that ran decent and didn't oil up))
the WR9LS I think, is for the thread length, Mercedes had longer threads (about 20mm) than Volkswagen plugs (about 10-12 mm).
If anybody wants to confirm this or correct any errors, be my guest.
6punkt3 is offline
post #3 of 7 (permalink) Old 12-12-2013, 08:26 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 696 Post(s)
Won't swear to it, but I don't think so. I believe 220SE uses W7DC.
GeeS is offline
post #4 of 7 (permalink) Old 12-12-2013, 08:38 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Originally Posted by 6punkt3 View Post
the WR9LS stands for heat rating or spark strength (9 is kind of hot for city driving only or if your motor fouls them up with oil or too much gas, I remember buying 8 or even sevens for my old finnies)
Could you explain this a bit more, how using a "cooler" plug helps with fouling plugs? What else is affected by this heat rating or more accurately what symptoms help someone know if we should move up or down in the rating? Much appreciated!
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #5 of 7 (permalink) Old 12-12-2013, 09:01 PM
Quoted: 11 Post(s)
better?
You misunderstood me.
I made some corrections above.
I AM NO EXPERT, by far, but what I had been told by different people in parts stores (way back) that a 7 is a normal all around (city and mostly highway plug), an 8 is hotter and for stop and go traffic.
9 I was told is too hot, too strong a spark (?)
I guess to answer your question:
the way I was told and explained :
a hotter plug is like running the car too lean of a mixture. It creates too much heat in the combustion chamber and you're risking a burnt valve (exhaust usually) or worse, the top of your piston melting.
sounds about right, I think the W7DC stands for copper (the good old Bosch opper or Plus plug before they started those stupid platinum things).
6punkt3 is offline
post #6 of 7 (permalink) Old 12-12-2013, 09:08 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
The spark plugs without the resister "R" work much better .Idling and acceleration is better.
W7DC was common on the fintails like 220S.
adler is offline
post #7 of 7 (permalink) Old 12-13-2013, 07:27 PM Thread Starter
50$84sd's Avatar
Thanks guys, that helps.
I do have some oil burning in 4 & 5 cyl. though, so although not a fix I assume these being hotter will help and not foul as fast.
I really don't drive the finny much and not for any long distances so really not about to do any internal work.
Or I guess I could get some plug extenders as those may help equally, thx. Later.
50$84sd is offline
