Engine 110.921 1974 280C Diagram! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-04-2013, 04:58 AM Thread Starter
Date registered: Nov 2013
Vehicle: SL63 AMG
Hello,
I need a engine diagram, I'm working to fix
a 1974 280C.
Thanks!
Jeff AMG is offline
post #2 of 6 (permalink) Old 12-04-2013, 02:02 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
Maybe describe what your problem is for us...
What do you mean by engine diagram?
rumb is offline
post #3 of 6 (permalink) Old 12-05-2013, 03:12 AM Thread Starter
Vehicle: SL63 AMG
About the problem
A few days I talked with the mechanic and he need valve shim
to valve adjustment procedure, but I don't know if this engine
use valve shim?
I would like to know the correct way to fix this engine.
Thanks about your reply.
All the Best.
Jeff
Jeff AMG is offline
post #4 of 6 (permalink) Old 12-05-2013, 05:59 AM
rumb's Avatar
Quoted: 488 Post(s)
Valve adjust shim is normal to compensate for wear. Your mechanic knows what he is doing.
rumb is offline
post #5 of 6 (permalink) Old 12-05-2013, 05:28 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
There are some things in the Online Resources section that might help...
Grubeguy is offline
post #6 of 6 (permalink) Old 12-05-2013, 07:59 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
The M110 has screw type adjusters on the ball studs.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
