Interchangeability of 4-Speed Gearboxes - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-15-2013, 02:54 PM Thread Starter
Date registered: Oct 2008
Vehicle: 1959 190, 1961 190SL, 1967 250SE 4Spd, 1968 220D 4spd
Quoted: 5 Post(s)
Was wondering today about the 4 speed gearboxes, and how/if they've changed over the years. The latest one I can think of is on the W202 cars. The earliest, probably intro'd with the pontons/gullwing/190sl. I know the yoke that sticks out from the top of the transmission varies (some are straight, others angle down, others are on the side), but the actual meat of these things (bearing size, bell housing mounting, etc), and they drastically different? People swap out differentials all the time to get more favorable gearing, but you don't hear much about swapping gearboxes. Could, hypothetically, I swap the gearbox in my ponton for something that will offer a longer final gear ratio?
elduderino is offline
post #2 of 3 (permalink) Old 11-15-2013, 04:10 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Pretty sure if your are dealing with a 4sp they all are going to have a 1:1 4th gear.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 3 (permalink) Old 11-15-2013, 04:31 PM Thread Starter
Quoted: 5 Post(s)
gah, you're right. and all 1st gears are likely similarly short.
