M130 engine removal\rebuild - Page 11 - Mercedes-Benz Forum
post #101 of 128 (permalink) Old 05-19-2014, 05:07 PM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
Did you have to remove your radiator support to remove the engine? I'm rebuilding mine this fall but don't know how to tilt the engine the required 45 degrees to clear the sub-frame. Maybe you raised the frame (if so, by how much?). Also, what's your garage ceiling height. Don't know if mine is high enough and I can't go outside to do it (HOA regulations!)
Kitaka is offline
post #102 of 128 (permalink) Old 05-20-2014, 06:06 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
Remove the bonnet to make life much easier.
You are going to need about 8' or better overhead clearance unless you cut the radiator cross piece.
Mike D is offline
post #103 of 128 (permalink) Old 05-20-2014, 07:23 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
You have to remove the hood.
Standard garage height is enough.
You must remove the radiator, which is so easy, just disconnect the hoses and lift up.
I also removed the manifold, head, alternator and power steering pump but it was not needed.
Going back in, i only had the radiator and the fan not installed. Everything else was in. Will post few pictures later.
I have to take the manifold out again as I have leak from the manifold bolts 5 and 6.
kavadarci is offline
post #104 of 128 (permalink) Old 05-21-2014, 01:07 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
May 21st, 2014 update
My 8 year old daughter started the car, first one to crank the rebuild engine and it started.
Mechanically run fun, no ticking, no knocking which used to be the case.
I do have leak from manifold studs, 5 and 6 I think.
I couldn't start the engine the next day. I think it was because the intake\manifold was flooded with coolant.
Next is to take the manifold out, apply sealant on the studs and tighten them properly.
Few days delay but at least I know the bottom end is good.
Few pictures attached.
ID:	954425   Click image for larger version
ID:	954433   Click image for larger version
ID:	954441   Click image for larger version
ID:	954449   Click image for larger version
post #105 of 128 (permalink) Old 05-21-2014, 02:59 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
you should not remove the studs , there is no reason for it , now see if you can remove them and seal them with permatex num 2 .
agillot is offline
post #106 of 128 (permalink) Old 05-21-2014, 03:56 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
How do I remove the studs without removing the manifold I can out two nuts in there there is not enough space. Unless there is a trick I don't know about.
post #107 of 128 (permalink) Old 05-22-2014, 06:13 AM
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
Forgive me if you have already answered this question, did you rebuild your carburetors or send them out to be rebuilt?
dgosh28 is offline
post #108 of 128 (permalink) Old 05-22-2014, 06:52 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
I sent them for rebuild, full rebuild by someone in Toronto area. i didn't want to touch them myself due to the number of components and not having bench to test them. carb one was missing idle needle, something i might not have noticed myself. I'm glad I didn't do them.
post #109 of 128 (permalink) Old 05-22-2014, 07:26 AM
dgosh28's Avatar
Quoted: 103 Post(s)
Thanks. The more I think about it the more I think I better send them out. My brother got a quote for me for $300 to do both. That is probably money well spent.
dgosh28 is offline
post #110 of 128 (permalink) Old 05-22-2014, 05:21 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
I paid 500
