Clatter on hard acceleration; 61 220SEb 4 spd - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-11-2013, 11:38 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1961 220SEb coupe, 75 450SL, 79 450SL
I have a 61 220SEb coupe, 4 speed. When accelerating, usually when pushing it, but rarely on easy acceleration, there is a clatter / knocking that seems to be in the area of the shifter. I have not replaced the rubber carrier for the center bearing in the drive-shaft yet. Shifter itself is rebuilt, and new bushings installed at the link points. Thoughts?
57Wayne is offline
post #2 of 6 (permalink) Old 11-11-2013, 03:36 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Could the clatter be coming from the engine itself?
I'd look to the exhaust and see if you have something bumbling on the chassis. At hard acceleration, your engine may be leaning over a little (meaning degraded/bad engine mounts) causing the exhaust to bump.
Grubeguy is offline
post #3 of 6 (permalink) Old 11-11-2013, 04:02 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I'm thinking worn engine mounts or tranny mount, either could allow enough movement for parts to potentially make contact. Check your emergency brake cable as well and be sure it is properly routed along the rollers and is tightened properly with no slack. While you're down there make sure your rubber exhaust hangars are all in place and not torn either. Sometimes they look ok but are hiding a split so grab each one and make sure it's not compromised. How's your flex disc? If it's coming apart it would open up more under greater RPMs and threads or a loose bit could be making contact. You can also put it on a lift and look for any signs of rubbing such as shiny parts on the exhaust or chassis, worn rubber, etc.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #4 of 6 (permalink) Old 11-11-2013, 05:46 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
check the 6 bolts at the u disc at trans , and rear mount .
agillot is offline
post #5 of 6 (permalink) Old 01-04-2015, 08:30 PM
Date registered: Jan 2015
Vehicle: 1965 220 seb coupe
that looks like a later engine than a 220 se, it has the 6 plunger injection pump which makes it a 250 or 280 engine, which is a nice upgrade if the original motor is lost.
there is a diagram on this page, but it doesn't explain how to overcome the 'spring'
Behind the wheel
love the car by the way, right on top of my car bucket list, but pretty much unobtainable in Australia these days except for those with plenty of cash!! (more than me anyhow)
All the best
eddie220seb is offline
post #6 of 6 (permalink) Old 01-11-2015, 08:17 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Front Flex coupling collapsing or cracked,also retighten loose bolts ,all checks as mentioned by agillot.
adler is offline
