wiper linkage? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-01-2013, 05:42 PM Thread Starter
Date registered: Oct 2013
Vehicle: 1976 220d
wiper linkage?
1976 merc 220d (115)
my driverside wiper works and the pass side dosent(i can move it freely by hand)
any common part break on these that i should just order??
clownracer is offline
post #2 of 6 (permalink) Old 11-02-2013, 06:34 AM
Vehicle: 1971 Mercedes 220d, Nissan Patrol GQ60
First of all locate the problem. The linkage is connected with a platic bushing and linkage arms which probably has come off due to a stuck passenger wiper arm. Since all the mechanism is under the windshield inside the car they are not prone to rust.
Look up under the dash under the steering wheel and you will see the linkage from the motor. From the left arm there is two linkages over to the right arm, one of those must have come of the passenger wiper arm. And if both linkages is connected, the inside of the wiper arm can be broken.
GiggleJuice is offline
post #3 of 6 (permalink) Old 11-02-2013, 07:43 AM Thread Starter
Vehicle: 1976 220d
Does anyone have a photo of how it is supposed to look all connected?
post #4 of 6 (permalink) Old 11-02-2013, 08:56 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
no , it is obvious when you look at it .
agillot is offline
post #5 of 6 (permalink) Old 11-02-2013, 01:03 PM Thread Starter
Vehicle: 1976 220d
I don't know how you could see it when it's in the car
I fixed it anyway found it was separated behind the guage cluster popped it back on works great now
Should there be a clip or anything retaining it on?
post #6 of 6 (permalink) Old 11-02-2013, 04:54 PM
Good! Like l predicted. No, only inspect the plastic bushing for wear, no clips. It can be a good idea to check why the linkage came of, so it doesent happen again.
