Sooo, I bought myself a new toy, and it broke within two hours! - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 11-09-2013, 11:34 AM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 292 Post(s)
I should be able to supply the emblems. There is not much beyond the rear emblem that is w115 240D specific.
By spotlight, do you mean the front fog? Round light between the grill and headlamp. I will need to inventory to see what all else I have. Front brake rotor for sure, window glass, some trim, and tail lamps
Clay
74 450SL - Froggy
'02 s320 - Victor
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'76 300D - Voldemort
'95 E300D - Cleo
'72 220D - Gump
'87 300SDL - POS SDL
92 300SE - #1 boys ride
redghost is offline
post #12 of 15 (permalink) Old 11-09-2013, 01:29 PM
Date registered: Dec 2012
Vehicle: 1984 300D turbo 1982 380SL 1981 380SL 1984 300SD
Quoted: 727 Post(s)
Originally Posted by enyt View Post
I am not sure that it is the same but my 1982 300d has the alternator and water pump on the same belt; that is why it needs to be repaired.
what caused the belt to break? I had my alternator seize once and that had to also be replaced.
heh heh.
My mistake.
benzbarz is offline
post #13 of 15 (permalink) Old 11-09-2013, 06:05 PM Thread Starter
Date registered: Oct 2013
Yeah, I need one fog lamp then, one is cracked, and also the trunk seal, and the rear passenger side door seal. I guess these items are of lesser importance to getting the car a bit more reliable though..
Today, I fitted then new glow plugs. Unfortunately, there was no difference in it's terrible cold starting (have to turn it over 3/4 times for a while before it eventually fires up.) Once it's warm it starts up straight away, runs smooth as silk, pulls cleanly, good oil pressure, water temperature solid as a rock etc.
One thing I did notice - the glow plug indicator light on the dash does not come on at all. Could my problem lie in the relay perhaps? Maybe the glow plugs aren't getting any power, and what (eventually) starts the car from cold is purely the heat produced by the repeated turning over?
BenA105 is offline
post #14 of 15 (permalink) Old 11-10-2013, 09:01 PM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
Hi Ben. I hope you have a dry place to store the car when the weather gets bad. There are a few weak spots on the body you should know about. #1 is the air intake or waterbox under your front windshield. #2 is the area around your front lights. Remove any dirt and inspect the fender coating. Remove the front mats and look for moisture. Also inspect the trunk and remove the matt. # 3 is the bottom of your doors .Hope everything is dry and no rust is showing. Good luck with your new toy. Harald
Over 75 is offline
post #15 of 15 (permalink) Old 11-12-2013, 03:51 PM
redghost's Avatar
Quoted: 292 Post(s)
Do not forget behind the wheel wells up front. That place likes to store muck. Easy to remove the panel and hose it out. Best to check all weep holes for function anyway. Window seals will cause cabin and trunk leakage/rust.
+1 on removing carpet/mat. Pull it all up and feel for dampness. The cabin mats are a sponge. If you do find rust, brush it to bare metal and then use POR-15 to protect. Topcoat with rubberized undercoating.
Clay
74 450SL - Froggy
'02 s320 - Victor
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'95 E300D - Cleo
'72 220D - Gump
redghost is offline
