First crank in years - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 10-25-2013, 06:54 PM Thread Starter
CoreyP's Avatar
Date registered: Oct 2013
Vehicle: 1971 250c
it is at a lot right by my house and the are allowing me to toy with iy before making the purchase. the engine does turn, im just making sure to check it out well before getting stuck with a lost cause.. also waiting for them to locate the title but things are in the works. as it stands asking price is only 500.00 so really i cant lose much but I also dont want to throw my money out the window. if i can get it running fairly quickly then i will be able to register it and not have to worry about my apartment complex complaining about an unregistered vehicle sitting around until i get moved into my house.
CoreyP is offline
post #12 of 17 (permalink) Old 10-25-2013, 07:05 PM
Date registered: Mar 2004
Quoted: 2 Post(s)
Jeez, $500 is all you are worried about? I thought you were talkin a couple thou. What's it weigh? You can probably get that much for it at the crusher if the motor is locked up. And why does it have to be running to register? Don't you just take the title to the DMV and get tags for it? I doubt they have emissions or safety inspections for something that old.
atikovi is offline
post #13 of 17 (permalink) Old 10-25-2013, 07:14 PM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
$500?
that is insane, buy it before it goes away..
don't need the url, click on the little staple sign and browse to your picture and then upload.
kavadarci is offline
post #14 of 17 (permalink) Old 10-26-2013, 12:53 AM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
Corey. Unless you have the cash and ambition to restore this Benz. I would buy it and sell it to anyone of us for $1000. Or there is lots of info. in this forum to keep you busy for a long time. Please store it in a garage and keep us informed of the progress on this car.
Harald.
Over 75 is offline
post #15 of 17 (permalink) Old 10-26-2013, 07:53 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 445 Post(s)
just from your profile pict it looks decent.
search this forum for carb / zenith rebuild, that question come up a lot. you will pay someone else @$500 to rebuild them or you can buy parts for about $100 and do yourself. when you get to that point there are great resources for setting them up correctly.
If everything is decent that a good scrubbing work bring back, then go for it at $500 is a good price.
depending what you want to do with it and how nice you want to make it, check out all the rubber bits, door seals, window seals, ect. these can add a bit.
assuming it doesnt have rust issue from back window into trunk and front cowl into footwells this seems pretty good. to get running well you might plan for upwards of $1000, that would be servicing everything including carb rebuild. still not bad to have running car for under $1500
more picts would help if you can do that. just click on the paperclip above where you type message and upload them.
rumb is offline
post #16 of 17 (permalink) Old 10-26-2013, 07:55 AM
rumb's Avatar
Quoted: 445 Post(s)
kav, gee you should buy it as a parts car for yours.....
Originally Posted by kavadarci View Post
$500?
rumb is offline
post #17 of 17 (permalink) Old 10-26-2013, 09:54 AM
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
If I were closer and had space by now it would have been in front of me :-)
I have no luck with finds like that in Canada
