M130 Crank pulley bolt - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-22-2013, 11:41 AM Thread Starter
ejp2fast's Avatar
Date registered: Nov 2008
Vehicle: '66 Mog 404.114
So i understand some M130's had a 27mm (1 1/16") socket for the crank bolt to turn the engine over (clockwise) by hand...
however, i have what is in the attached picture...
any suggestion how to turn my engine over by hand?
Name:	m130 crank pulley.JPG
66 Mog 404.114 with 12.5R20's powered by M130
ejp2fast is offline
post #2 of 6 (permalink) Old 10-22-2013, 03:08 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Remove spark plugs
Remove spark plugs
Engine should be easy to turn over by rotating harmonic balancer
Matvh is offline
post #3 of 6 (permalink) Old 10-22-2013, 03:08 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 511 Post(s)
get some 3/4" square stock, drill 2 holes and insert bolts that stick out.
rumb is offline
post #4 of 6 (permalink) Old 10-23-2013, 05:34 AM Thread Starter
ejp2fast's Avatar
Thanks for the tips - what m130's have this style pulley and the bolt style crank pulley?
ejp2fast is offline
post #5 of 6 (permalink) Old 10-23-2013, 07:52 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
this engine got butchered , looks like the 27 mm bolt head got chopped . never seen that .remove the spark plugs , and turn engine at cam , you can do it , i described the way before , read it again .if you have a good tensionner / chain , you wont have any problem
agillot is offline
post #6 of 6 (permalink) Old 10-28-2013, 08:40 AM Thread Starter
ejp2fast's Avatar
how exactly do you chop a 27 mm bolt? is that even possible? the center has a rubber boot/cap - and i am going to pry that out and see if there is a smaller bolt inside. It has to come OFF somehow right?
ejp2fast is offline
