Inspect your oil tube holes, here is my seized bearing. - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 10-09-2013, 08:45 AM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Originally Posted by carpenterman View Post
For those contemplating a tube inspection/clean, I would suggest removing the tube altogether and a good wash with solvent and compressed air. Just poking the tubes with a wire is liable to just push the sludge back up into the tube where it can re-lodge in the holes.
You are absolutly correct. If you do the inspection without removing the tube and see any sort of sludge on just even one hole, you do want to remove the tube (takes less than five minutes) and run some solvent and compressed air through it like Carpenterman suggests.
Originally Posted by agillot View Post
this is a very rare problem , only seen it a couple of time in 40 plus years .
Glad to hear that it's not a very common problem. After I get the new camshaft and bearings in, I will inspect them at least once or twice a month just for peace of mind.
Luna Gaudi's 72 250 is offline
post #12 of 12 (permalink) Old 10-09-2013, 08:55 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 34 Post(s)
In the m117 v-8 engines, this is a fairly common problem. It usually just plugs one of holes which leads to a lifter and cam lobe failure. The replacement oiler kits for the v-8 is $5 per side. I had 2 failures over the course of 140,000 miles on my old 450sl. $10 to prevent every 50k miles or so sure beats $500 to fix once you ruin a cam.
TZ_280SEL is offline
