Hydropneumatic spring leg assy 1969 280 SE Convert - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-27-2013, 10:41 PM Thread Starter
Date registered: Apr 2013
Vehicle: 1953 220a cabriolet, 1969 280 SE convertible
Anyone know where I can get this part rebuilt. My reared is a little low and doesn't level after running for a period. Or? Could it be an adjustment to shocks?
Any help, guidance or steering appreciated. Classic center is $2000 plus for rebuild. Ouch!!! May be my only answer, but would prefer a less costly answer. Is change to spring an alternative?
Thanks
Tami@baysidefirst.com is offline
post #2 of 8 (permalink) Old 09-28-2013, 07:54 AM
Date registered: Jan 2009
Vehicle: 1970 280 sel, 1979 300sd, 1988 300sel
Quoted: 10 Post(s)
Are we talking about this part:
SLS | 32/35.i Info Hydromat W110, W111, W108
I did not know that the Classic Center was rebuilding them. They are probably sent some where else for repair.
xaliscomex is online now
post #3 of 8 (permalink) Old 09-28-2013, 08:40 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 458 Post(s)
Due to the high cost of rebuild and the certainty that it will fail again, most put the spring in and then never worry about it again.
rumb is online now
post #4 of 8 (permalink) Old 09-28-2013, 08:07 PM
Quoted: 10 Post(s)
My aftermarket spring caused a positive camber in the rear. When looking at the back of my car the rear tires looked like this \-----/. Purchase the correct spring. I believe the classic center sells the correct one.
post #5 of 8 (permalink) Old 09-29-2013, 12:06 AM Thread Starter
Kind of knew the answer before I asked. Thanks to responders.
post #6 of 8 (permalink) Old 09-29-2013, 06:54 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Compensating Spring
This is a photo of the compensating spring used on my 69 MBZ
I recently changed the rubber spring pads used on both sides of the spring.
I believe you can order various thickness of these rubber pads to adjust suspension sag / height
Matvh is offline
post #7 of 8 (permalink) Old 09-30-2013, 10:36 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
use the spring , you could get the parts from a junk yard from the right car .
agillot is offline
post #8 of 8 (permalink) Old 09-30-2013, 11:06 AM
Jackpody's Avatar
Vehicle: Mercedes Benz W108 - 280 SE (1970) / Mercedes-Benz W123 200T (1983)
Quoted: 13 Post(s)
Yeah, spring is the best way these days.
Here's a picture of my set up.
Jackpody is offline
