Back window defroster control?? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-24-2013, 09:12 AM Thread Starter
Cheetahpop's Avatar
Date registered: Mar 2013
Vehicle: 1971 220D
Restoration of my '71 220D is going well (got it inspected and on the road! And rust-free!!), so now I have time to think of other things, such as... where's the control for the back window defroster?
And what did the little knob between the preglow resistor and the key insert used to control? It's connected to a push-pull wire (not electrical) that has been cut.
Cheetahpop is offline
post #2 of 7 (permalink) Old 09-24-2013, 05:08 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
The "thumb screw" knob between the key and the pre-glow indicator is an idle adjuster. When the engine is cold you turn it and it's like stepping on the accelerator a little bit. Use it like you might use a manual choke (it's not a choke - it does not change the fuel mixture it just increases the throttle)
If yours is broken either your car is difficult to keep running at idle when it's cold or it idles too fast when hot. They are relatively easy to fix or replace. The one end is just behind the knob and it goes through the firewall up to the top of the engine on the drivers side. There it is connected to the throttle linkage.
I'll try to post a photo if I can find one.
You can find all of the parts you'll need easily.
Sent from AutoGuide.com App
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #3 of 7 (permalink) Old 09-25-2013, 04:21 AM
Date registered: Oct 2010
Vehicle: Mercedes
Quoted: 9 Post(s)
Exactly that, if yours is broken I have a new one for that model, original one
javimx5 is offline
post #4 of 7 (permalink) Old 09-25-2013, 04:12 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
idle speed increase adjustment .
agillot is offline
post #5 of 7 (permalink) Old 09-26-2013, 03:20 PM
frankflynn's Avatar
Vehicle: 1973 220D
Quoted: 2 Post(s)
Here is a photo of where the other end goes
post #6 of 7 (permalink) Old 09-28-2013, 06:10 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Thanks a lot, guys. That's it! Nothing in the manuals about it...
post #7 of 7 (permalink) Old 09-28-2013, 06:11 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Thanks! That's it! It should be easy to find the other end when I get to it...
