What is the correct Choke richness setting? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-20-2013, 10:52 AM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
I read about this a while back, but I cannot seem to find the info anywhere. What is the correct setting on the choke "starter cover"? As you can see in the photo, the cover mark is set at the yellow arrow, should it be there or rotated to the line where the cyan arrow is pointing? The manual on the jaimekop site ( http://www.jaimekop.com/CarbManual/Page18-19/index.html ) shows that it needs adjusting, but it is not very specific to where it should be adjusted to.
Thanks guys!
Name:	choke adjustment with arrows.jpg
Luna Gaudi's 72 250 is offline
post #2 of 5 (permalink) Old 09-20-2013, 06:12 PM
Date registered: Aug 2006
Vehicle: 1972 300SEL 4.5, 1971 Citroen DS21, 1995 Jaguar XJS
The manual says the rear one should be a bit rich when the car is new and then they should both be at the center line after the first service
since that was 40+ years ago they should be at the center line..
I have noticed that in some cars, the bi-metallic strips inside are old and binding and the choke doesn't pull off correctly unless the covers are adjusted a bit to the lean side, so I would use trial and error to find what works for you. there are other adjustments on the Zenith chokes, the top screw is a trim for example
good luck !
tcb323 is offline
post #3 of 5 (permalink) Old 09-20-2013, 06:35 PM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 82 300D,90 350SDL, 98 S420, 97 SL500, 94 S420, past owner W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 680 Post(s)
The center line is a reference point and nothing more.
Depending on the climate you live in, you may need to adjust these seasonally. The mark is just a place to start from and not a whole lot else.
Dan
LWB250 is offline
post #4 of 5 (permalink) Old 09-20-2013, 11:07 PM
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
the closed air gap has to 2.2 mm for perfect starts.
ad
adler is offline
post #5 of 5 (permalink) Old 10-06-2013, 05:53 AM
Date registered: Sep 2013
Vehicle: 300 d 124 c250d 202
Hi choke covers were set at datum mark at factory,when vehicle came for first service had to be retartded by 5 mm (earlier opening) change in emission rules Germany and Australia where I am. Choke covers for these engines and M130 had different Bi-Metal springs,23 for front & 18 for rear if memory is correct. Rear choke activated via 60 degree thermo switch, front via terminal 15 (IGN), front opened earlier & has fast idle adjustment, rear no adjustment. Pre Throttle Gaps should be 2.4 mm when engine has started and running, (220 SB with ZENITH 2.6mm).
om diesel is offline
