W114 M130 valve springs - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-20-2013, 09:16 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
A mechanic looked at the engine today and believes the engine ticking is not due to bearings timing or chain
It is from the top of the engine
His suggestion is to start replacing the valve springs and inspect the rockers
Does anyone know how to take these springs out without removing the camshaft or I have to take the camshaft out ?
Thank you
kavadarci is offline
post #2 of 4 (permalink) Old 09-20-2013, 09:47 AM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Gald to hear that it might be as simple as springs and/or lifters. A whole lot easier than tearing the engine apart. I will check my Haynes book.
Luna Gaudi's 72 250 is offline
post #3 of 4 (permalink) Old 09-20-2013, 10:14 PM
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
There is a special tool for depressing the valves in situ,no need to remove cam.(ebay)
I think that it is very rare for the springs to make a noise.
If it is a ticking noise similar to loose tappets the pressure pieces or the rocker arms may be worn, possibly cam bearings.
Do replace each shim and rocker in its original place or more noise!
adler is offline
post #4 of 4 (permalink) Old 09-22-2013, 04:55 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
never seen a spring causing this , a flat cam or a rocker arm with a flat spot .rotate engine so the cam fully depress valve and take a close look at the surface of the rocker .do not overtighten the valve cover , this will cause a noise because the brackets will touch the rotating cam .
agillot is offline
