low grill 280se coupe 6 cyl vs. a 3.5 transplant - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-18-2013, 04:59 PM Thread Starter
Date registered: Nov 2012
Vehicle: 84 300 DT, 69 280 SE Cp low grill, 09 C 300, 68 280 SE, 2 350 SL 4 sp, 65 220 SEb Cp, 92 500E
I have a '70 280 se low grill coupe that I just picked up. Car has a bad head gasket as a best case scenario Maybe worse. Not sure yet.
Thinking of maybe a 3.5 transplant. I have found 2 350 sl's with 4 speeds.
Has anyone taken out the 6 and put in a 3.5 4 speed? Worth doing? Any major problems or red flags?
It would be great to have a 3.5 4 speed coupe. I am pretty sure they did make the 3.5 coupe with 4 speed from the factory.
Thanks in advance for your help.
rockingchairmotors is offline
post #2 of 5 (permalink) Old 09-18-2013, 08:55 PM
Date registered: Apr 2012
You might find some answers, inspiration or reality here: '62 220SE Coupe 5.0 Presentation
Palolo is offline
post #3 of 5 (permalink) Old 09-19-2013, 01:27 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
The 3.5 111 manual transmission driveshaft is different. It is a 3 piece unit with 2 center bearings.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #4 of 5 (permalink) Old 09-19-2013, 08:10 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
Good score!
Search also for threads with 'Frankenbenz 450' in it, as I have put a 450 V8 into my W111 sedan. It is definitely do-able and proves a nicer driving experience than the 6, but there is more to it than just plonking the 8 in the engine bay. Things like: handbrake cable route, exhaust around the steering box, engine mount arms, throttle linkage, wiring, possibly the fuel pump. And you will need to find a diff from a V8 W108 to get a numerically lower ratio.
Also search for a thread called something like 'W111-108-113 mods' as it has some good stuff in it.
I am a fence sitter as to whether it is worth it - my current coupe project is a 250SE that is taking the standard driveline, then the next one is either an E55 AMG or M119 from a 500SL into a W112 coupe.
Good luck, Drew
drew56cus is offline
post #5 of 5 (permalink) Old 09-20-2013, 11:42 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Suggest Re-do the inline 130 6 engine .well regarded for reliability and longevity.
May not be a good idea chopping ,altering bits here and there to fit a 3.5 engine in a coupe and It will not have the feel of the original car .
I am doing a overhaul on the 3.5 engine from my 300sel 3.5 . the injection system with trigger points, a two stage tps and very expensive injectors and other fueling parts are a negative point. It was a comparatively primitive first generation D injection system.
adler is online now
