1965 Mercedes-Benz 220 Sb fuel PSI/CARB? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-06-2013, 10:53 AM Thread Starter
Date registered: Nov 2010
I installed a electric fuel pump to help with starting and general drive ability.
How much fuel pressure should be at the carbs? I am currently using a very low pressure fuel pump. It shows zero psi because the fuel returns to the tank. If I pinch of the return line I get about 2.5 to 3psi. Is that enough or do I need closer to 6 psi?
hwyix is offline
post #2 of 2 (permalink) Old 09-06-2013, 04:38 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
You are in the range specified for your carbs. My electric pump is rated at 5 psi but there are no problems. I did install a check valve which probably drops the pressure some.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
